BJ8 brake master cylinder question
Digger
I am replacing the brake master cylinder, and I ordered a new one, Moss # 581-102. The catalog indicates that this is the one for a BJ8 with the servo.
When I tried to install it, it seems that the diameter of the new one is too large to fit the hole in the firewall. I checked the diameter of the hole with a digital caliper, and it is 1.325". I have the old master cylinder that I removed some time ago, and across the rubber cover (dust shield?) it measures 1.44" (between 1 and 2 on the photo) I know I took it out, and I assume that it will compress the rubber somewhat to fit the hole.
However, the new one measures 1.59" at the same point, (between 3 and 4 on the photo) and I don't see how it is going to fit.
Also, the outside diameter of the shaft on the old one (between 5 and 6 on the photo) is 1.25" and the new one is 1.34" (between 7 and 8 on the photo).
Did I order the wrong part? I recognize that the old master cylinder may not be the original, although I have owned the car since 1979 and haven't replaced it. Is there some technique that I don't know that would make this fit in the hole in the firewall? I am perplexed. Any suggestions would be appreciated
A
Digger:
Send the old original one to White Post there in Virginia and have it rebuilt
Digger, I'm not sure if you are measuring the diameter of the rubber cover between 1 and 2 (also 3and 4) or the actual metal with the rubber removed. In order to install the master cylinder through the firewall, you first have to pull the rubber boot off the cylinder and slide it down the rod. Then insert the rod into the hole in the firewall, push the rubber boot through the hole, bolt the MC to the firewall and then from inside the car, slip the boot back on the lip of the MC. Last step is to attach the rod to the pedal. The MC will not go through the hole with the boot in place.
Rob,
That works for the old one I took out, but not for the new one. I am going to follow the advice to return the new one and have the old one rebuilt by White Post.
Thanks for all of the comments.
Thanks for the clarification. Good luck with the project. I wish the designers had given us a tad more room to access the clutch MC. It's a bear.
It should be a piece of cake on an English--i.e. RHD--car.
Edit: Do the RHD cars have the voltage regulator on the port side?
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
letemglow Brake master cylinder BJ8 Austin Healey 0
LAW75 BJ8 Brake Lines Austin Healey 2
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
Marvin Gruber BJ8 brake booster Austin Healey 6
wangdango BJ8 brake reservoir? Austin Healey 7
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
H BJ8 Exhaust System and Brake Servo Austin Healey 16
Bob_Spidell Brake Pads for BJ8 Austin Healey 24
Marvin Gruber BJ8 brake booster picture Austin Healey 4
Marvin Gruber BJ8 brake connectors Austin Healey 17
F Front brake hose BJ8 Austin Healey 4
F front brake hose 67 BJ8 Austin Healey 4
J Emergnecy Brake Cable Replacement BJ8 Austin Healey 4
P Brake boost repair, BJ8 Austin Healey 10
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
B BJ8 Rear Brake Questions/Advice Austin Healey 4
BOBBYR BJ8 Brake Booster Austin Healey 13
R BJ8 with servo...Brake travel issue Austin Healey 30
R BJ8 Brake Drum Removal Austin Healey 6
C question on the front brake lines for BJ8 Austin Healey 2
L BJ8 Brake servo Austin Healey 6
P BJ8 Brake Booster mount Austin Healey 9
T Soft brake pedal on BJ8 Austin Healey 3
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
S BJ8 rear brake drums Austin Healey 8
healeyneil Sticking back brake BJ8 Austin Healey 0
J BJ8 brake light not working? Austin Healey 2
C BJ8 brake fluid disappearing Austin Healey 11
C BJ8 brake servo options Austin Healey 5
J Late BJ8 brake rotor- thickness specs Austin Healey 5
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
WALTER BJ8 w/o brake booster? Austin Healey 4
J BJ8 Brake Booster Austin Healey 5
C AH3000 BJ8 Brake Caliper question Austin Healey 7
R 67 BJ8 Brake Light Switch Austin Healey 2
R 67 BJ8 Brake Fluid Resivor Austin Healey 6
R BJ8 brake calipers Austin Healey 14
S BJ8 Emergency Brake Lever Loose Austin Healey 1
D brake light problem 67 BJ8 Austin Healey 4
BoyRacer Wanted BJ8 engine block - Wanted Austin Healey Classifieds 5
S Wanted *** wanted: front right frame section for 1967 BJ8 3000 *** Austin Healey Classifieds 8
J BJ8 Choke Cable - Plastic Covers Austin Healey 5
AUSMHLY BJ8 1st into 2nd Austin Healey 0
Mickey Richaud For Sale 1965 AH BJ8 Phase 1 Austin Healey Classifieds 1
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 12
