Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
Hi guys. The '67 TR4a did not originally have an OD so I need to run wires from the newly added switch... Anyone been there/done that and have some lessons learned to pass along?
Extra bonus points for ideas that minimize having to disassemble stuff. Grin.
I did this on a TR4 -- just ran the wires down the same 'dagger' as used for the turn signals, etc. That area may be a bit more crowded on a 4A if (as I think) the headlight switch is on the column and uses that same route.
I had to add a D-shaped hole in the right side nacelle, maybe you will too.
It is arguably easier to purchase the proper escutcheon, part number 611974, which has space and other provision for the correct OD switch. Readily available from all the usual suspects! Of course, this advice applies only to the TR4A and later, as Geo suggests.
Are the replacements metal or plastic (I honestly don't know). When I did mine it came with a right hand escutcheon with D-shaped hole but it was plastic -- I chose to drill my original metal piece.
I think all replacements are plastic, as were most OE from about 1964-ish on. Years ago, I parted a circa 1963 TR4 with OD; it had metal escutcheons. I might still have the escutcheon and switch somewhere....
I think the plastic/metal cutover point was right at the 4/4A change. On the 4A the switch is on the left side, doubled up with the turn signal switch. For TR4 the right one had the d cutout for the switch if overdrive was installed.
Hey Tom... welcome back by the way!
Since don can't find his D-drill, you might consider going to a square drill bit. Yes, I can supply one if needed....
