TR4/4A Any tips on re-torquing TR4a head now that 500 are on the rebuild
tdskip
Any tips on re-torquing TR4a head now that 500 miles are on the rebuild
Hi guys - hope everyone is doing well.
Any tips or things to be aware of on doing the re-torque of my head now that I am at 500 miles on the rebuild?
Engine should be warm?
Anything else to be aware of?
Thanks!
Hi, As you are going for the full monty, 104 Ft lbs and I'm guessing an extension bar on the handle. Try to use just the socket on the wrench, no extension there. If you did not replace the studs there is a good chance on stripping the threads at this tight a torque.
Best advise, if it feels funny, STOP!!!! live with what you got.
Wayne
Are you going to loosen the nuts about a quarter to half (one at a time) before final tightening ?
As far as the temperature, I've done both ways without harmful consequences so I don't know if there is a 'right or wrong' way of doing it.
I usually do the re-torquing like poolboy does, except I only do a re-torque with the engine cold.
1/4 turn de-torque and then re-torque, one nut at a time in the workshop torquing order.
M.
TR3 manual says to do the nuts hot, but I couldn't find that line in the TR4 manual. I doubt it makes much difference on an iron/iron engine. I did, however, find a note that says to wait (or do it again) until 1000 miles.
As Ken says, you should loosen each nut slightly before retightening, then get the torque reading while the nut is still moving. This avoids the sticktion (aka static friction) effect.
Book says 100-105 ftlb, which I interpret as 102.5 ftlb plus or minus 2.5%. In other words, the range is to allow for inaccuracy in your torque wrench (and your reading of it). Shoot for the middle, not the top.
There is a lot more strain on those studs & nuts when the engine is running, than when you retorque the nuts. So IMO if something feels "funny", it's best to find and fix the problem now, rather than having a leak later on. That said, I have never had a head stud on a TR3 give me any problem (although I have found a few that were stretched from over-tightening).
One other thing I like to do before loosening for a re-torque is put a dab of paint (I use a yellow paint pen) at the same spot on each nut - say, at the forward edge. That way I can see after I'm done just how much more each nut moved to achieve correct torque.
Really, no idea how to use that info - I am just curious as to how much a of correction was needed.
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
J Tips for quarter elliiptic spring install Spridgets 3
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
PC DIY tips from Bo his self Other Cars 0
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
drooartz Installing front hubs, tips? Spridgets 15
bugedd Bench bleed tips Spridgets 14
S TR4/4A Electrical wiring tips Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
F Buying a 100.... tips Austin Healey 18
drooartz MGB Changing clutch hose - tips? MG 13
T Tips for Searching FORUM Navigation Questions 2
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M tips please on removing starter motor on 100-6 Austin Healey 6
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
bugedd Su adjustment tips Spridgets 7
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
PatGalvin TR2/3/3A Carpet Install Tips Triumph 12
Bob_Spidell Tips Austin Healey 6
Tinkerman TR2/3/3A Front Fender Installation Tips Triumph 3
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
W Looking for tips: BJ8 roll up windows Austin Healey 10
I TR6 Any tips on removing flasher switch Triumph 3
M Radiator Hose tips? Spridgets 0
T TR4/4A Any tips on running the overdrive switch wiring down the steering column? Triumph 11
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
bugedd About to rebuild front end...any tips? Spridgets 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
apbos Two Restoration Tips Spridgets 11
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
5 TR2/3/3A TR3 engine building tips needed Triumph 5
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
Lbp Install l-t-d fasteners on new tonneau - Tips? Triumph 8
T Wheel cylinder fitting kit - any tips? Triumph 4
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
J 67 IRS Exhaust Tips Triumph 2
RickB Painting tips anyone? Spridgets 13
RJS Water Pump Replacement Tips Triumph 8
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
aeronca65t Kasnter tips Triumph 8
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
drooartz Any tips for replacing brake hoses MG 16
