Advice needed in removing front left fender.
GerryL
I have removed all the bolts from front left fender except for the one that is accessed from inside the car's side kick pannel. There does not appear to be a bolt to be removed. I can slide the fender back and forth aprox. one inch. It appears that it is stuck at he area where the bolt should be. The right fender does have a bolt which can be accessed from the side kick pannel. Any suggestions?
Have finally removed fender. Bottom on fender missing (rust) which allowed a better view. The captive bolt was present but bolt was not present. Just kept on sliding back and forth and upward until fender released. It must have been rust which would not let go. Another little battle finally won. The car constantly challenges me.
Gerry - These bolts are hard to install when it comes time for you to put the fenders back onto the front of your TR3A. For my TR3A, I took a normal bolt 1/4-28 UNF about 3/4" long and welded the threaded end of another similar bolt, but about 1-3/4" long to the head of the shorter bolt. This makes it look like the long bolt is standing on the head of the shorter bolt. Now you can use your fingers to get the bolt assembly started and with a 7/16" socket, it becomes really easy to tighten the bolt with the socket on the head of the long bolt. Once it's in and the interior trim is installed, no-one can see the "trick" bolt.
N Electrical Troubleshooting Advice Needed Spridgets 6
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
F Water pump replacement on my BT7 advice needed please Austin Healey 18
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
R Remove engine/transmission advice needed Austin Healey 4
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
L Advice Needed Austin Healey 30
L Advice Needed Spridgets 20
M Some Tech Advice Needed for Horn Brush on 59 Bugeye Spridgets 10
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
A 100/4 Fuel pressure advice needed Austin Healey 1
R Bugeye rear wheel advice needed Spridgets 20
B Another Restoration Thread - Advice Welcome [and Needed] Austin Healey 25
JPSmit Truck diagnostic advice needed [I suspect it is dead!]] Other Cars 7
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
dklawson Spitfire My Spitfire Mistake - Advice Needed Re. Head Gaskets Triumph 14
D Car Buying Advice Needed Please :] Other Cars 2
DerekJ Paint removal - advice needed Austin Healey 13
PatGalvin TR2/3/3A Accelerator Pedal Advice Needed Triumph 21
JPSmit Engine Analyzers advice needed Restoration & Tools 8
O Battery box install- advice needed! Spridgets 4
1 More advice/knowledge needed MG 4
R Expert advice needed Spridgets 10
R Possible Midget purchase - advice needed Spridgets 11
T T-Series TF Parking Brake Disassembly Advice Needed MG 2
A master cylinder advice needed Triumph 7
M 1275 Exhaust Manifold Needed - Along with Advice Spridgets 5
M Door weatherstrip repair advice needed MG 4
Morris Emergency advice needed Spridgets 13
JPSmit OT phone wire advice needed Restoration & Tools 5
healeynut Steering Wheel restoration - advice needed Other British Cars 0
healeynut Steering Wheel restoration - advice needed Restoration & Tools 7
T Rebuild/Restoration advice needed. Triumph 23
J painting over por15 - advice needed. Restoration & Tools 7
newmexTR3 emergency advice needed! Blown pushrod Triumph 17
T Wedge TR8 passenger floor - advice needed Triumph 7
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
B TR2/3/3A Advice needed - cleaning TR3 brake pipe union Triumph 11
B Looking for a TVR - Some advice needed TVR 12
S Advice needed - 56 MkI 2.4 Jaguar 32
jjbunn Advice Needed: Batteries and Hole Plugging Triumph 29
Morris Oil pressure prob— advice needed Spridgets 7
R TR6 TR6 Steering wheel advice needed Triumph 6
Mg_Bizzle Considering 2nd hand engine, advice needed MG 26
T Crypty's front hubs-advice needed Triumph 58
RickB Advice needed - is it possible to... tach & choke? Spridgets 4
fmichaels tub advice needed Spridgets 2
ahpook Boy, will my wife be mad. Advice needed... Spridgets 19
RobT Permanent Garage Advice Needed Triumph 58
RobT Temporary Garage Advice Needed Triumph 16
