A bit more progress
Mickey Richaud
Gorgeous, Ray!
BuggerAll
Aha, mounting an HIF? Two things I found helped with mine: 1/ make a heat shield (I used sheet aluminum and that thermal fabric which is sold as protection for starter motors - starts first pop no matter the heat soak) and 2/ if you are using the HIF, get one of the big motorcycle part catalogues and get the HIF float bowl extender, adds a couple of ounces to the bowl, again helps resist vapor lock and fuel starvation on cornering, costs about $15.
Gundy
She's a beauty! Can't wait for the Varoooom posts.
W
Whitephrog
The factory painted the original 948cc engine and smooth case transmission Morris engine green. The 1275cc engine was also painted Morris engine green but the ribbed case transmission was left natural aluminum. Since I have the 1275cc engine and ribbed case transmission in a Bugeye I decided to paint both green. Correct color for the car but not for the transmission.
JPSmit
looks great - almost like a toy or doe cast just because of the three bold colours - green/ bright yellow and white in the background - cool!
drooartz Bit more progress tonight, nearly there Spridgets 21
Tabcon A bit more restoration progress with pics. Triumph 24
healeyboz a bit more progress for me too Spridgets 5
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Hap Waldrop Acme Speed Shop just got a bit more speedy Spridgets 13
aeronca65t It's a bit more tidy now. Spridgets 7
jlaird Just a bit more on activities at the Lake Spridgets 3
DrEntropy A bit more eye candy! Other Cars 25
regularman A bit more work done today. Spridgets 9
drooartz A bit more teardown Spridgets 32
drooartz Found a bit more knee room in the Tunebug Spridgets 4
DrEntropy MGB A bit of disappointment MG 4
DrEntropy Bit of Historic Lotus News Lotus 0
DrEntropy Bit of nostalgia: Other Cars 14
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
JPSmit Interesting bit of trivia tonight Other British Cars 0
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
roscoe Distributor problem [a bit weird] Austin Healey 15
Gundy Runs a bit...then quits Spridgets 18
HealeyRick Runs a Bit - Then Quits Spridgets 23
Brinkerhoff TR4/4A Belgium built TR4A, is a bit unusual ! Triumph 16
Rut MGB Last little bit MG 0
I BJ8 is running a bit rough. . . Austin Healey 7
drooartz Bit of history on my new Bugeye Spridgets 0
B Engine Dieseling a Bit at Shut Down Austin Healey 12
M_and_P A bit of flex British Motor Corp 5
drooartz Off Topic Okay, this is a bit classier than the duct tape MG 4
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
G One bit the dust Triumph 12
drooartz A bit of workbench art MG 4
G Spitfire Bought a Spit today, a bit bummed out Triumph 12
T TR4/4A TR4A - A Type OD Solenoid - need a bit of help Triumph 7
RickB A bit scary this morning - ice Spridgets 22
KVH These Leaks are a Bit Shocking--Even for a TR Triumph 7
PC power bit to square drive socket adapters Restoration & Tools 3
Morris Had a bit of insomnia last night... Spridgets 3
glemon 11/64s drill bit tranny mounting trick Triumph 10
5 Is this bit off a healey? Austin Healey 8
jlaird Doing a bit of something. Spridgets 26
Wizardd MGB '77 MGB runs for a bit, then shuts down MG 28
angelfj1 PROJECT UPDATE - A Bit of Progress Triumph 13
drooartz Brosky, nice bit in the papers! Triumph 12
jlaird A bit of battery info Spridgets 4
Morris If only it were this easy...[ a bit OT ] Spridgets 5
MGBGT_noob T-Series Clutch mater cylinder little plastickey bit MG 2
NutmegCT A bit of history Triumph 14
W A bit of progress Spridgets 14
DrEntropy Bit of eye candy: Other Cars 26
