TR6 70 TR6 Brake Booster
Jacmo
Member
Brakes on the 6 are extremely poor--requires very hard push on the pedal. What are the diagnostic procedures for the booster? I've never dealt with one before.
Thanks!
--Jack
John_Mc
I had a torn diaphragm in mine which made the pedal go soft to the floor with minimal braking. It required a real hard push then. Had the diaphragm repaired and that essentially solved the problem ( I say "essentially" because I think I still need to bleed the system a little more). The torn diaphragm was caused by fuel backflow through the vacuum system. The anti-backflow valve (real name escapes me at the moment) was replaced also. As far as diagnosis goes, I knew something like that would be the problem because there was an audible hiss when the pedal was depressed (vacuum leak) and the engine would run rough. That's one possibility to investigate. Cost me $125 to rebuild the booster.
G
Bad hoses will do that too. Who built yours for $125 and how long ago?
John_Mc
I took mine to a local place called Power Brake Exchange. They had it done for me in about 1 hour. I'll have to double check the price. $125 is what I recall, but it may have been more. This was probably 3 or four months ago.
Minesweeper
Thanks!
--Jack
One test is, with the engine off, step on the brake pedal and start the engine. If there is no drop in the pedal, then you know the booster is not doing its job for some reason. If so, its usually is an internal problem with the booster. Brake Materials & Parts Inc. in Ft. Wayne does a great rebuild for a good price.
Scott
sundown TR6 1973 TR6 brake booster hose Triumph 7
I TR6 69 TR6 brake booster Triumph 2
B TR6 TR6 Brake Booster/MC Rebuild Triumph 5
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
J TR6 TR6 Brake Question Triumph 1
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J TR6 TR6 Brake Pad Shims Triumph 1
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
A TR6 '73 tr6 passenger front brake dragging Triumph 2
C TR6 TR6 with dot 5 brake fluid Triumph 8
smaceng TR6 TR6 brake pressure balance valve Triumph 2
D TR6 76 TR6 New Brake Bleeding Triumph 4
D TR6 76 TR6 Rear Brake Installation Triumph 17
D TR6 76 TR6 Brake Servo Triumph 2
D TR6 76 TR6 Rear Right Brake Line Triumph 8
bobh TR6 TR6 Brake Upgrade Triumph 19
W TR6 TR6 brake pedal drip Triumph 12
D TR6 TR6 Puddle of Brake Fluid on the floor Triumph 8
M TR6 Tr6 Brake Pull Triumph 6
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
sundown TR6 TR6 e-brake Triumph 2
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
hondo402000 TR6 TR6 power brake bleeder Triumph 10
Phil73 TR6 TR6 brake issues Triumph 13
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
Z TR6 TR6 Brake Issue Triumph 8
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
I TR6 TR6 brake squeal Triumph 8
bigbadbluetr6 TR6 TR6 Brake Problems Triumph 6
mabbott TR6 Brake fluid in 73 TR6? Triumph 6
T TR6 Anyone have a spare TR4/TR6 brake master lid? Triumph 4
I TR6 TR6 - how many brake caliper shims? Triumph 26
Brosky TR6 Really BIG Brake Kit for TR6 Triumph 15
I TR6 A few dumb TR6 brake questions Triumph 9
TR6oldtimer TR6 TR6 Brake caliper part. Triumph 6
TR6oldtimer TR6 TR6 brake calipers Triumph 6
TR6oldtimer TR6 TR6 Hand Brake Install Triumph 2
I TR6 Rear brake drum temperature TR6 Triumph 13
hondo402000 TR6 Front Brake issues TR6 Triumph 2
hondo402000 TR6 figured out my low brake peddle problem TR6 Triumph 1
hondo402000 TR6 TR6 rear brake rebuild Triumph 10
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
B TR6 TR6 Disc Brake rattle Triumph 2
AngliaGT TR6 Found the TR6 Brake Problem Triumph 5
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
