Before you do the rebuild, check the float levels one more time; critical with the SUs. Also, sounds like you're still 2 turns down on the jets. Run them up to see if things change.
SU pumps sometimes half-work, filters sometimes become partially restricted. Forty-five years for rust to develop in a tank, sediment can cause some strange conditions.fuel pumps work and then they stop. Filters get plugged and flow stops.
Make sure the fast idle screws aren't causing the linkage to bind.I've followed your instructions and have managed to get it to run off choke but I can't get it to idle below 1100rpm. I'm not sure how it runs under load yet as I'm currently blocked in by a van but I'll try it tomorrow. Can't thank you all enough for all the help.
Dave.
great news. In terms of idle, it took me a long time to learn to set it with the engine hot. good luck and keep us posted!I've followed your instructions and have managed to get it to run off choke but I can't get it to idle below 1100rpm. I'm not sure how it runs under load yet as I'm currently blocked in by a van but I'll try it tomorrow. Can't thank you all enough for all the help.
Dave.
