The last 3 weeks were spent on the seats. The seats that came with the plane are "McArthur" pilot seats. They are not original to the Stearman, but were outfitted late in the war during depot overhauls. Mine were patched and broken, and I was not looking forward to repairing them. At the Stearman auction last month I managed to pick up 2 stainless steel seats...also not original, but more in the original style. These were used in P40's and B-26's, and, of course, could have been outfitted to the Stearman as replacements.
When I got the seats home I realized they were pretty rough. I tried welding a hole, and realized 28 gage stainless is beyond my ability. The seat was originally built using tack welds. I welded what I had to, and avoided the rest. Each took 2 full days with hammer and dolly to try to fix the dents. One seat was painted and had to be stripped and polished. Then, the height adjusters were broken, only one had a shoulder harness lock, and all of the mounting straps were missing and had to be custom fabricated (about 2 hours each).
Here is the model and serial numbers for the seat. Likely came out of a P-51 or some other fighter. I mention P-51, as many Mustang parts were at the auction.
This shows the back of the rear seat. The seat is held to the mounting rails with 4 straps. As you can imagine, these straps were a pain to fit...the originals were missing. They have to be tight enough not to bang back and forth if you pull negative G's, but loose enough to easily slide up and down the rails. You can also see the green shoulder harness locking cylinder. This had to be ordered from ebay and custom fit to the back of the seat. It allows the shoulder harness to move with the pilot, but also incorporates a lock if you are going to crash land. This is a "HUGE" deal when you think about it. In my plane's crash the daughter was wearing a locked harness and walked away from a vertical crash without a bruise. The pilot did not have the lock and required 100 stitches from hitting the instrument panel.
And, here is a view of the bottom of the seat with all the controls. I had to fabricate most of the little fittings and rods, as the originals were broken or bent beyond repair. The sides are the height adjusters, and the middle rod is for the harness lock.
And here is the front seat installed:
Those with sharp eyes will notice that the rear cockpit instruments are really close to the front seat. It turned out the vacuum line to the Turn and Slip indicator prevented the seat from raising full up. Bummer. I then managed to crack the case on the T&S indicator trying to re-route the lines. Double Bummer. A used indicator off Ebay, and 3 weeks later, I had the indicator repaired and seat functioning properly.
