G
Hi everyone. I own a 76 MG Midget which has the Spitfire 1500cc engine. I had a failure of the tolerance ring which holds the fan and fan clutch assembly to the water pump. The 13 blade plastic fan and fan clutch rubbed against the back side of the radiator. I need a 13 blade plastic fan. New ones are not available (that I know of). Does anyone have a nice used 13 blade plastic fan? Thanks.
