16P Calipers
Rocky_LC
I have Girling 16P calipers on the front of my ‘71 Vixen 2500.
It was built in April 1971, so I would assume the brakes match up to a 1970 TR6?
The calipers have the following on them:
16P 645
CA20047
I think they would match the early TR6 calipers from Moss Motors, but just want to make sure.
Thanks
There is a 16p and a 16pb
Pbs are metric and have a different dust seal. If yours have the V shaped seals then they are 16p.
They look like P to me. Moss will have all the bits you require along with SS pistons. Use a lot of Girling grease when fitting the cups.
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
jjbunn Type 16P brake calipers - replacements? Triumph 13
TRMark Installing dust seals on 16p Triumph 1
K Is there more than one type of 16P brake caliper? Triumph 14
H Rebuilding Girling 16P Triumph 5
jjbunn Wanted: 16P LH Brake Caliper Triumph 21
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
TomMull TR2/3/3A The ABCs of Brake Calipers Triumph 10
G Adding a Brake Booster / Brake Calipers Austin Healey 3
T TR2/3/3A Brake Calipers Triumph 7
S TR6 Need wisdom on tr6 brake calipers Triumph 6
Ripper01 For Sale Brake Calipers w/ pads- 2 Triumph Classifieds 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
John Turney TR6 Brake Line to Front Calipers Triumph 4
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
K TR2/3/3A Brake Calipers again. Triumph 1
A TR2/3/3A TR3 Gods were good to me, got pistons out of calipers today Triumph 1
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
D Brake calipers rebuild Austin Healey 13
George Zeck Binding Calipers ?? Spridgets 8
S TR6 brake calipers Triumph 4
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
maxwedge5281 who rebuilds front calipers? Austin Healey 19
RAC68 Dimensional Differences [brake Calipers] Austin Healey 5
DanLewis Wilwood calipers $100 NFI Spridgets 0
tr7andtvr Wedge TR8 calipers? Triumph 3
L +2 rear calipers Lotus 5
TR4A_IRS General TR Calipers for Sale on Seattle Craigslist Triumph 3
6 Brake Calipers Spridgets 14
S TR2/3/3A A type tr3 calipers Triumph 5
hondo402000 New uprated spindles and Wildwood calipers Triumph 11
hondo402000 TR6 Wildwood Calipers on TR6 Triumph 19
S Spitfire Question on front calipers 1973 spitfire part Triumph 9
BobbyD Latest Upgrades: VTO Wheels & Wilwood Calipers Triumph 7
B TR2/3/3A Swap early TR3A rotors/calipers for later? Triumph 3
M Spitfire Spitfire MK2 calipers Triumph 4
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
davidb AH 3000 brake calipers Austin Healey 6
middie Have I damaged my brake calipers? Spridgets 9
P MGB MGB Calipers = Morris Marina Calipers? MG 0
E brake calipers MG 0
Rut Rebuilt Brake Calipers Spridgets 31
P Spridget Calipers Spridgets 25
T What to do with OEM calipers? Triumph 8
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
Jim_Gruber Ooops, how not to remove calipers Spridgets 3
Tabcon Front brake calipers Triumph 15
Tabcon Front Brake calipers Racing 19
