Everyone: Here is what I think is the answer to the problem.
On the '89 on Marelli ignition cars, the ignition amplifiers consist of two DAC 4607 units mounted on aluminum plates that act as heat sinks. there are four wires to each amplifier. The cable passes from the top of the engine near the left side of the compressor to the radiator top support and then splits into a "Y" feeding each amplifier separately. I don't know if I would have chosen to mount them on top of the radiator though. Also mounted to the top support are two clamps or brackets that support the air conditioning receiver drier. The clamps attach to two threaded studs on each side that stick up vertically. The clamp/bracket is securred with nuts and washers to those studs.
The cable "Y" passes on each side of the l/h rear stud. Each amplifier is secured with two screws that connect to nut plates.
When I was connecting everything back after reinstalling the engine, the cable for the r/h amplifier apparently passed right over the top of the stud. There is very little clearance. When the hood (bonnet) was closed it crushed the wire on top of the stud hard enough to cut through the glass fiber cable sheath and through the plastic insulation on one of the wires shorting out the r/h amplifier.
It could have just as easily been the l/h amplifier cable.
The car would not start, so I openned the hood and started checking wires. I did not find anything, but apparently moved the wire harness from on top of the stud. Without the short, the car started, but the damage was done. I don't think the r/h amplifier has been working correctly since then.
In examining the front engine harness looking for anything that I might have overlooked, I discovered the cable outer sheath cut and the insulation cut on one of the wires.
I swapped out the amplifier with a spare unit and got an immediate improvement in power and fuel economy. The spare amplifier unit I had was suspect so I ordered a replacement.
The Original DAC 4507 has orange plastic. That has been superceded by DAC 11520 that has white plastic. I do not think the two can be intermixed. They also cost $285 each!!!!
John Farrington;
Check the 92 you are working on to see if either cable is cut. If not, consider swapping amplifiers out to see if the problem resolves! I had an intermittent problem before in which the amplifier would short internally when hot and the ignition would kill. If the car sat for a while, the amplifier would cool and the short went away and the car would start. I never could determine which was the problem at that time and had to replace them both. Now this problem.
I don't have full power yet, I'm going to have to check the r/h side cats to see if they are damaged as a result of all of this.
In my case, the wire that shorted still allowed the ignition to work once the cable was moved. The 92 may have shorted a different wire to the amplifier and "fried" it.
