92 XJS Air Conditioning Questions
PK1973
Please bear with me as I am new to the XJS and I am translating from my mechanic. The problem I am having is as follows:
The heater core was replaced recently after initial purchase. On replacement the air conditioner was only blowing from the demisting vents at the top of the dash. Vent control having no effect on air direction. Upon testing my mechanic found good vacuum presure, but flaps werent opening all the way to deflect air. Motors were swapped demister for center, this resulted in air coming from center but not demister working that way until turned off. When restarting air was not coming from either outlets and no vacuum. The solenoid is only producing 5-7 volts. We are both reading over Kirby's documents as well as Jaguar repair manuals, however need additional guidance.
Questions we have are:
What should voltage be at solenoid be carrying? 12volts?
By swaping motors with one working partially is the original center motor bad/since its not working in the position of the demister?
Could the problem be with one of the computer control units which seem to be everywhere on the XJS? If so which?
Any other suggestions as to how/what to trouble shoot?
Thanks in advance
Having the defrost flaps open is the default position. No vacuum usually produces this. All solonoids should be 12 volts activated, 0 volts off. The drive for the servos is from the AC ECU, the piano looking thing on the right side of the climate control box. To make diagnosing the climate control a whole lot easier, I reccommend that you get the factory wiring diagrams(S57 for XJS) and also get the same thing for the equivalent year XJ40. They can be found on Ebay if you look. The XJ40 diagrams have all of the input and output voltages for everything in the system. The systems are nearly identical, so having both diagrams in front of you helps. You can check everything for proper voltage, and the diagnosis is a lot faster. That being said, the center vents on XJSs are notorious for failing. They can be accessed only by removing the dash.
Thanks alot for the info, and will look for the diagrams. I have had the car only for a couple months and I am still learning where the bugs and are at. The first two months were to make it mechanically sound, now I'm on the creature comforts.
Under the radio is a slide lever that determines the amount of air going to the top vents as well as to the foot wells. What position is the slide lever in?
> foot wells.
In my 1991 XJ-S that lever controls only the temperature of the air from the center vent. It does not vary the volume of air from any vent.
Michael,
Had to grab the pastic and order parts, still waiting on delivery. Solenoid, motor and AC ECU (ouch)
It is the Delnaire III system with no mods that I am aware of.
The vehicle was an ebayer and within my intial price range. The moment it came off of the truck, I went for gas and car wash. After going through the wash the windows started to fog up. Turn on the defroster and whooooooooooosh.....
Water into the cabin, fried radio and since then been working on what I can or out sourcing to dealer and local garage.
M Replace V-12 90 XJS Air Cond Expansion Valve Jaguar 7
M Purple Air Injection Hoses 90 XJS V-12 Jaguar 2
M XJS Fuel Injector, Air Temp Sensor, Water Temp Sensor Harness Connector Replacement Jaguar 0
JPSmit Jag XJS convertible Spotted 0
D 1992 jaguar xjs abs Jaguar 1
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P XJS Jaguar 20
M For Sale For sale - xjs parts Jaguar Classifieds 0
JodyFKerr Tempted by an '88 XJS Jaguar 9
Steve P. carbs for XJS V-12 ? Jaguar 2
Steve P. Newbie with XJS...opinions wanted Racing 9
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
CZ_Dave 1990 Jag XJS Jaguar 1
B 86 xjs trans dipstick Jaguar 0
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
M 1990 XJS Catalytic Converters Jaguar 5
H 1988 xjs battery condition indicator ? Jaguar 8
T OT - vintage XJS hill climb video Triumph 0
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
D 1988 xjs--no start Jaguar 2
RichBall XJS/12 In lynnwood Wa Pull-A-Part Jaguar 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
tony barnhill 1995 XJS Convertible Jaguar 10
T 1990 xjs conv -" A "brace Jaguar 2
R 1996 Jaguar XJS transmission cooling line removal Jaguar 0
V '90 XJS waist molding question Jaguar 3
X Oil For My XJS Jaguar 7
boeingpilot Someone help me buy an XJS! Jaguar 10
jackq Found an 88 XJS V-12 locally. Jaguar 11
W new shocks for jag xjs v12 ? Jaguar 3
M 90 XJS Antilock Brakes Question Jaguar 2
beachbumbarry XJS Vehicle maintenance Jaguar 7
beachbumbarry XJS AutoTrans and Differential Fluid Change Jaguar 1
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
M Jaguar XJS factory alarm system. Jaguar 14
X XJS Manual Gearbox Kit. Jaguar 1
Wray XJS Coupe V12 Jaguar 11
M Manual Transmission Kits for V-12 XJS Cars Jaguar 3
D facelift xjs coupe speeakers Jaguar 0
D 1992 facelift xjs transmission problems........... Jaguar 1
D xjs heater conrol lighting Jaguar 2
D facelift xjs central locking............... Jaguar 0
R early 87 jaguar xjs suspension upgrades Jaguar 2
tony barnhill XJS Rouge Coupe Jaguar 5
D xjs v12 tire wear Jaguar 1
D 1994 xjs 6.0 $2 free delivery worldwide. Jaguar 4
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
D xjs gearbox jerk Jaguar 4
