Wrapping your headers is it worth it?
73MidgetLigon
Im running my stock 1275cc with a DCOE 45 I Made my own heat shield for the dcoe im wondering is it worth it to wrap my headers?
Also iv seen this question asked before but never very completely answered Is it going to help/hurt me any to take out my thermostat? i am constantly having to fight with it getting to hot im wondering if this will help
If you already have a heat shield, I doubt wrapping the headers will do much. I had a vapor locking problem once, and in trying to eliminate it I wrapped mine, which seemed to have zero effect. Mostly that just made a big mess when I had to drain the coolant, since the block drain was right above the exhaust pipe. Messy.
Removing your thermostat will not help with overheating. It may actually make things worse if you take it out, because it regulates the coolant flow so it only flows when it's hot enough. If you take it out, coolant will always be flowing, and may not be soaking up enough heat while it's in the block.
Header wrap will lower the under bonnet temps and to some extent, shorten the life of the headers due to rust. Removing the thermostst will help if you put in a blanking sleeve. No blanking sleeve=no help. If your overheating is in city traffic, the electric fan will help quite a bit. Best is an electric "suck-through" fan in place of the waterpump fan blades.
Running a hot 1275 with a turbocharger has forced me to try out every possible temp reducing scheme over the years. The above tips coupled with a Speedwell aluminum radiator and 11 row oil cooler have been the answer.
Glen Byrns
The fan blades attached to the waterpump pull air through the radiator, but not much air when you're waiting at a light. The electric fan should be all you need. I turn mine on manually instead of counting on a thermostat that turns it on too late to prevent trouble. As soon as I hit 190, I turn on the fan, or as soon as I get caught in traffic.
Glen
My Mini has its original header wrapped. I was told this would shorten its life but I already had patched it in several places and didn't think I had much to loose. Most people say that ceramic coating works equally well at reducing under-hood temperatures without shortening the life of the header. However, I have no first-hand experience with ceramic coating. I can say that wrapping the header will lower the under-hood temperatures.
In the Mini world, engine temperature in the U.S. is always a concern. When people have built high-performance 1275 engines like Glen-B discussed above, a fairly common fix is to buy a heater core from an American car and plumb it in as an auxiliary radiator. I'm not sure where you could mount such a solution on a Spridget but just increasing the volume and surface area would probably help some.
Don't forget about running Water Wetter instead of anti-freeze for the summer.
Cleaning the inside. They take the top and bottom off and run a rod through the passages the water flows thorugh to clean em really good.
If you have any oil in your engine comp. wrapping the headers is a bad idea because if the oil gets to the wrapped headers, you have a serious problem. Its a potential for fire. I had a good rad. gone through by a rad shop this last winter, its OK driving around town, but it gets hotter on the highway. I really dn't think it is realistic to beleive that all the scale is removed in the tubes, and any left just isn't helping the cooling of the rad. Think heat transfer through the scale. That leaves either an aluminum rad or recore your present rad with a 3 row core. I think either decision is a good one.
If you live in a hot area, that's not a bad idea. My bugeye came with both an electric fan and the pump fan in place. The guy who restored it lived in the desert near Sacramento, and he took cooling pretty seriously. Of necessity. I have had no problem with overheating, even in traffic and on 100-degree days, although under-hood temperatures are obviously high and the carbs make the running a little sputtery at times.
The electric fan is on all the time; it has its own fuse and is wired into the switched power, with a relay to minimize current in the ignition switch. I have thought about a thermostat, but keeping it on permanently doesn't seem to hurt.
B TR4/4A Exhaust Wrapping Triumph 8
Jim_Newman exhaust wrapping Austin Healey 5
drooartz Tunebuggery Day 9: wrapping it up Spridgets 16
3 Exhaust Manifold/Headers BN2 Austin Healey 16
steveg Headers to buy - DW or AHspares? Austin Healey 5
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
R General Tech Kirk Racing headers opinion Triumph 3
Bremer TR2/3/3A 4-2-1 headers [or Tri-Y] Triumph 5
R TR4/4A Were the exhaust headers painted on the TR4's Triumph 6
D Headers for BN4 Austin Healey 2
Morris Good Deal on Cheap Headers Spridgets 6
T TR6 TR6 [?] headers - actually any good? Triumph 7
bighealeysource Derrington style exhaust headers on 100-4's Austin Healey 4
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
racer_x Wedge TR8 Group buy- Kirk headers Triumph 5
racer_x Wedge TR8 Headers: Rimmers versus Woody/TSI Triumph 34
JPSmit Patriot Headers Spridgets 1
Aggudabbu LCB/ Headers clearance issues? Spridgets 4
LuckyLuke Who makes exhaust headers for AH 3000 BN7 Austin Healey 7
W TR6 TR6 aftermarket headers Triumph 26
hymodyne GT6 GT6 headers Triumph 14
KVH TR4/4A Tubular Headers/Pertronix for TR4 Triumph 12
NardisCNC Who makes the best headers?? Spridgets 9
drooartz How the *bleep* do you fit the headers? Spridgets 11
RSMTR8 Wedge TR8 Headers Triumph 13
GBRandy Wedge Headers on a FI TR8 Anyone do it? Triumph 9
5 Headers for BN4/early 3000 Austin Healey 10
drooartz Jet-Hot headers came today! Spridgets 5
boeingpilot GT6 GT6 Headers Triumph 3
tony barnhill Patriot 1500 Midget Headers Spridgets 3
A new headers Austin Healey 3
chrisc Wedge TR8 Headers/Exhaust Triumph 46
G I called Jet Hot about my peeling SS headers... Triumph 20
amcboy Headers, and what I intend to do about it.... Triumph 4
G Jet Hot coating peeling off my headers........... Triumph 9
T tvr 2500 headers TVR 0
Darrell_Walker Headers/exhaust manifolds for 4 cyl TR with Webers Triumph 12
S headers ? Triumph 20
G Catalyst location for a car with headers Spridgets 17
DNK E bay headers Triumph 0
G Removing my engine/tranny with Headers.... Triumph 4
T ok, lets talk about headers Triumph 9
T TriumphTune Exhaust Headers? Triumph 23
A TR6 Headers --VS.--Stock header??? tr6 Triumph 32
Brosky Pacesetter Headers Yes or No? Triumph 13
kodanja TR6 71' TR6 HEADERS Triumph 6
T TR4/4A tr4 headers-sizing Triumph 1
C Don... Those Headers? Triumph 11
M 'Kirk Racing Headers' need feedback Triumph 2
