hondo402000
well from what I have resourced, there are several versions of the 40DCOE, mine end with 151 and read the idle screws should be between 2 1/2 to 3 turns out and mine are right there, the idle jets are a pain
F6,F12,F9,F8,F11,F13,F2,F4,F5,F7,F1,F3 are the desiginations from rich to lean
the F number denotes the air bleed hole size, and then the fuel hole sizes can go from 0.3mm up to 1.70 mm, in 0.05 mm steps so getting these right can be a real pain. If you are trying to jet webers, best to buy a set of small drill bits from mcmaster carr and drill them out in .05 mm steps, so you dont have to keep ordering jets, thats what I did, and once you get it right you can order the correct jet, if you want the numbers on the jets to match whats in the carb. or do as I did and just make notes
hondo
hondo
