hondo402000
Ok guys, tuning webers is an art not a science, I got the weber book, read it like the bible, and every thing I do has the opposite effect as to what the book says, I have an AF meter that I run, last run it was running rich, but still stumbles around 3000 rpm, so I go from 115 main jet to 120 guess what the AF ratio goes from 11.5 to 12.5 then go up to a 125 main jet and the AF ratio goes up to 13... not what its suppose to do, the stumble gets better but still there., so I go from a 180 Air corrector jet to a 175 which should make it run rich in theory in the upper ROM range but it gets leaner but runs a tad better. but still a slight stumble at 3000 to 3500 rpm.. so I guess I am just going to have to go by feel and not by the book, so I will keep trying different combinations , make notes and disreguard the book next step is to go to a 130 main jet and see what happens
stay tuned
Hondo
stay tuned
Hondo
Hi Guest!
