Weather factor
M
Member 10617
Just back from a warm-up drive. The car (TR3A) ran exceptionally well. The weather was warm (about 85 degrees) and humid. I've notice this before: the car seems to run very well under such conditions. Is it my imagination, or does this kind of weather make a difference?
NutmegCT
hmmm, warm and humid air. The aviation researcher in me says "warm humid air = thin air" (moisture makes the air less dense). Aircraft wings have less "lift" in warm humid air; more lift in cool dry air.
So if you're referring to how the engine was running, running well on warm humid air may indicate you have the mixture set well for "thin air", but not set well for dry (dense) air. Have to balance fuel with air intake.
Just my two cents.
Tom
M
Member 10617
Tom,
"Dry air"... ha, ha. It's been humid or raining here almost every day for most of the spring and early summer. I think we've forgotten what dry (dense) air is. You have given me some good information, however, and when fall arrives and the air is dryer around here, I'll rebalance the fuel and air intake.
Many thanks!
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
algot1901 Weather stripping and rubber parts Other British Cars 1
R TR2/3/3A Weather strip adhesive Triumph 11
R TR2/3/3A Weather Gear Triumph 3
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
Rob Glasgow Hardtop Weather Austin Healey 10
R Very Difficult cold weather starting problems! Austin Healey 21
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
KVH General Tech Help With Rusted Weather Strip Channel Triumph 1
steveg Healey hot weather driving observations Austin Healey 2
NutmegCT Window weather seal repair Restoration & Tools 4
M_Pied_Lourd TR2/3/3A Storage of Weather Gear Triumph 12
NutmegCT How to remove old weather stripping Restoration & Tools 8
bugedd How is your driving weather? Spridgets 12
GTP1960 TR2/3/3A Weather seal between apron & wings? Triumph 4
Sherlock Jensen FF [in winter weather!] Spotted 5
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
R Choke Not Working In Cool Weather Austin Healey 15
Rut Weather Spridgets 17
M TR2/3/3A Weather question Triumph 9
Trevor Jessie Confused about top down driving weather [off topic] Spridgets 43
T Soft Top Weather proofing on100 4 Austin Healey 12
E Lovely weather in the UK today Triumph 9
F Replace 1500 Door Fuzzy Weather Seal Triumph 3
tahoe healey BJ8 wind screen top weather strip Austin Healey 19
A Nice weather, no Sprite! Spridgets 3
DNK Weather Pack Restoration & Tools 0
G TR6 TR6 door rattles/weather stripping Triumph 0
tahoe healey Rendezous weather. Austin Healey 1
B BJ7 Weather Strip Installation Austin Healey 2
dougie PNW Dry Winter Weather Austin Healey 7
memphis Door Window Weather Strip Austin Healey 3
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
PATR8 Well the early nice weather was great Triumph 2
nevets No weather for a drive in the Healey Austin Healey 6
angelfj1 Today's Weather - So nice that . . . . Triumph 5
theleisure Cold Weather, Oil Pressure Spridgets 10
bighealeysource Weather proofing a garage Austin Healey 3
Morris Driving weather! Spridgets 50
T Weather and Transportation - alternate thinking? Spridgets 43
S Jag barely runs in cold weather Jaguar 7
tr7andtvr 280I weather strip source TVR 1
Woodie window weather strips Spridgets 3
B Nice weather - Got some stuff done Spridgets 5
mrv8q Today's weather report... Triumph 68
RickB Cold weather and oil viscosity? Spridgets 8
kodanja Cold weather Effecting Performance? +- Triumph 35
Z Sebring weather Spridgets 2
B HEAVY WEATHER ALERT!! Tyler,Texas Regionals Triumph 2
