tr6nitjulius
Use to dread spray washing or any water in engine bay for cleaning after long road trips, sometimes engine wouldn't turn over, moisture under dizzy cap, had to wipe under side of dizzy dry.
Current Waterless: Other foam tire cleaners may do the same but haven't tried. Spray liberally, saturate entire engine bay & parts, top to bottom (except chromed) grungy covey hole area below brake servo, entire engine block, green hoses, battery, between engine & battery, wires, back of radiator, rack & pinion, plug wires to block/dizzy, top of dizzy, fuel pump, front of engine, grill, front of radiator, timing chain cover, air horns, coil, radiator fan (bump starter to rotate) let dry, reapply should you want.
Note: Applied to/tested on non-TR 1st, don't take my word for it, be your own judge. While TR6 on jack stands for new aluminum flywheel/clutch. Scraped off 1/8"-1/4" caked on oil/grease/dirt grime (another 5-8 lbs of weight gone) sprayed over entire frame nooks & crannies. Once a year clean with a tad of chrome polishing
