vacuum advance for triple webers
hondo402000
side draft webers dont have ports for vacuum advance so after pondering the idea of where the vacuum is picked up on the original strombers I decided to drill holes in the housings of my webers on the intake of numbers 2,4,6 they are before the butterfly so I am hoping it will give some vacuum advance, here is a pic of what I did. it still runs so I didnt philips it up so far ( having trouble with the pic format) My question is, is there any vacuum reading at idle from the vacuum line at the dist?
will post pic later
Hondo
Should be none at idle, vacuum starts with the throttle cracked.
Another way to accomplish the same thing is to use a throttle-activated vacuum switch. Friend of mine rigged a microswitch plus a 12v vacuum solenoid. Saves drilling into those expen$ive carbs ...
well for some reason I cannot up load a pic and I know how I like pics. I have up loaded jpeg pics before
Hondo
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
WHT Vacuum Advance Pipe Austin Healey 7
JPSmit Today's question - vacuum advance Spridgets 2
B Vacuum Advance Pipe Austin Healey 2
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
D TR2/3/3A Vacuum advance tube Triumph 6
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
T MGB Vacuum advance and Electronic ignition conversion MG 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
AUSMHLY Vacuum advance knob Austin Healey 21
DanLewis Vacuum advance question Spridgets 5
apbos H1 SU vacuum advance frustration. Spridgets 9
DMShuman TR5/TR250 TR-250 Vacuum advance module.... Triumph 5
C TR4/4A TR4A with TR3 distributor and Vacuum Advance Triumph 4
Tinkerman TR2/3/3A 1960 TR 3A vacuum advance line installation Triumph 7
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
S TR2/3/3A vacuum advance tr3 Triumph 2
S banjo type fuel lines--vacuum advance Triumph 0
D '78 Midget Vacuum Advance Unit Spridgets 7
TulsaFred Bugeye Vacuum Advance Spridgets 5
M a discussion on Installing new vacuum advance unit Triumph 20
DrEntropy Vacuum advance or vacuum leak?! MG 2
SkinnedKnuckles Ported vs Manifold Vacuum Advance Triumph 5
G Anyone have a vacuum advance for a 45DM4? MG 4
Tinkerman TR2/3/3A TR3A Vacuum Advance Suction Tube Tool Needed Triumph 8
Tinkerman I Having A bad vacuum advance line day Triumph 5
Tinkerman TR2/3/3A TR3A Vacuum Advance Line Triumph 2
Tinkerman TR2/3/3A TR3A Vacuum Advance Hook Up Triumph 13
A Mk 1 Frogeye Vacuum Advance Spridgets 6
A Mk1 'Frogeye' Sprite Vacuum advance connections Austin Healey 2
jvandyke vacuum advance question Spridgets 5
Stinger TR4/4A TR4A Vacuum Advance Question Triumph 16
G New Spark Advance Vacuum Triumph 1
L Vacuum Advance question Spridgets 9
C vacuum advance hose Triumph 12
spit71 Spitfire My Spitfire doesn't have a vacuum advance Triumph 14
Tinkerman Vacuum Advance Rebuild? Triumph 2
zimmy vacuum advance Spridgets 17
