Tune up / Maintenance question
mikeamondo
Super quick question.... going to do basic tune up stuff... coolant flush, oil change, plugs.... Anything special needed here? Any particular oil needed, certain plugs to get?
I know this info is likely on here somewhere, but I did search and couldn't find it....
Thanks!
M
yes. you need oil with ZDDP for flat tappet engines, so, I would stay away from synthetic (it is available but you won't drive that much)
Diesel engine oil works as does motorcycle oil but you can still get regular oils also I use Castrol GTX. I also use 1/4 lucas oil stabilizer - I know there is debate about additives but I find it increases the oil pressure just a bit.
Plugs are available but use the proper ones.
It might be worth getting the rad properly flushed (and the engine for that matter) as the cooling systems were never awesome and 50 years take their toil.
(others on the board do Bugeyes have the issue where they need the longer rad cap? - someone else can answer)
Thanks for info! What are the 'proper' plugs for the car?.... it's a 1275, not the original 948. I've already checked the radiator cap style, at it's correct. The car is running slightly hotter than I'd like... creeping north of 200. The coolant in there looks a little old.... or a lot old. My guess is it's 5+ years or even more. I figured new fluid and flush is the starting point.
And are you referring to the regular Castrol GTX off the shelf at my local Advance?
y
You really need to get a shop manual, for engine oil I use Valvoline VR1 20w50.
For plugs, just go to the parts store and ask them for plugs for a 1970 MG Midget. Nothing special.
I prefer NGK for plugs and yes a BE requires the deep reach radiator cap. Agree with Trevor. A shop manual covers all that stuff plus lube intervals.
Cool... I bought NGK's! Changed the fluid and upper and lower hoses. Took the car for a short drive but long enough to heat up... may have dropped a few degrees... it was pretty hot still (outside) and he didn't go over 200.... plugs and oil are next up....
Odd. Tune-up involves plugs, points, condensor, rotor, set dwell and timing, replace fuel filter, inspect and/or clean air filter. Adjust carb(s).
Coolant flush is....coolant flush. Oil and filter is...oil and filter.
As far as ZDDP being necessary...I run flat tappet on the Jag and both flathead Fords. I have NEVER used an additive. Rebuilt two of them (one due to 300K and the other due to the clueless last person in). I have NEVER had a lifter or cam issue.
Like "OMG! You have to tear your engine down for hardened valve seats!". Yeah, if they are cast into cast iron heads, or known to be non-hardened. Jag is not changed....who knows how many miles...when I fixed the scrXw-ups, lapped the valves and that was it. I have never had a burned valve/eroded seat on the Flatheads. Ever.
OK, here I go with my usual harangue....
This hangup with ZDDP has gone way farther than it every should have. Almost all oils, including most of the (infamous) "starburst" ones, have adequate ZDDP, and virtually all in the viscosities we use (like, 20W50) have more than enough. You especially don't need ta ZDDP additive, and, in fact, adding extra without calculating the final concentration could cause engine damage. It's easy to get so focused on the ZDDP issue that you are tempted to do something really inadvisable, like using diesel oil, with is just not formulated for passenger cars.
Here is my take on the subject: https://www.nonlintec.com/sprite/oils_and_zddp.pdf
And an article from a GM oil expert: https://www.nonlintec.com/sprite/oil_myths.pdf
As for hardened seats, I suspect they might be prudent for an engine used for extended periods at fairly high speeds (like, freeway driving) but for most of our cars, which don't get that kind of use, I think you can confidently get by without them. As with the ZDDP, the need is likely overstated by familiarity and repetition.
Patrick67BJ8 Detailed Tune-Up Notes Austin Healey 2
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Tune Up Trouble Austin Healey 24
S TR2/3/3A tune up Triumph 12
4tecdog Stage 2 tune 1293 Spridgets 7
D My First Tune up Austin Healey 14
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
K TR2/3/3A Tune up refesh questions..... Triumph 1
S Best Top Down Tune Spridgets 36
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
C 65' 3000 Tune Up info/help for Prom? Austin Healey 3
bighealeysource Anyone have a good SU tune up article for BN2 Austin Healey 11
M 123 ignition tune mapping Austin Healey 0
toysrrus TR6 "NEW" TR6 Tune Up Parts For Sale in the Classified Triumph 2
JPSmit Italian Tune Ups and Ms Triss Spridgets 4
robdmau New to a Sprite, tune ups.... Spridgets 31
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
tr6nitjulius TR gets Dyno Tune Triumph 5
M TR2/3/3A TR3 Tune Up Triumph 16
Moseso A Tale of a Sunday Tune-up Triumph 13
dougie Test and Tune Racing 4
wkilleffer MGB What's the best way to tune an MGB? MG 19
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
B TR6 Another novice question re:TR6 tune-ups and chokes Triumph 9
B TR6 TR6 Tune-up guidance Triumph 14
D Tune-up Foul-up Triumph 37
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
RickB Quick ? -Tune up tools -Craigslist - Timing light Spridgets 9
B Bugeye won't start after tune-up Spridgets 17
B Tune up sequence??? Spridgets 9
RickB MGB-GT Starting tune up of my 70 BGT MG 24
Editor_Reid AH 100 Tune-Up Cost Austin Healey 5
BritCarFan A/C could use a tune-up, I think Jaguar 6
M Tune up Triumph 1
AUSMHLY The next project...the tune up Austin Healey 15
R Electrical tune up Q's Triumph 8
Paul Slice Changed my tune....... Triumph 2
I TR6 69 TR6 tune up tips Triumph 15
Mark_Gibson TR6 Tune Up Tips for TR-6 Triumph 14
B new member 5.7 tune port in a 7 series bmw? Other British Cars 13
Nunyas oooooooo... aaaaaaaahhh... How to Power Tune... MG 11
J Zenith Stromburg 175 carburator tune? Other British Cars 3
Patton Tune up to isolate a Low Power problem Austin Healey 2
C tune up time Triumph 3
X Dyno/tune social Jaguar 4
T Color Tune Restoration & Tools 9
Basil Color Tune Restoration & Tools 7
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
