TRouble with the TRans tunnel and Speedo Pinion
rlich8
Alright, well, I'm having a heck of a time with the trans tunnel and the speedo pinion.
I got my new trans tunnel and have attached the seal adequately. I absolutely cannot get this thing to go in. It seems as if the speedo drive pinion / right angle drive extends into the cockpit too far.
Are there different lengths of the speedo drive pinion? The car has overdrive, and it did not originally. Perhaps this trans was taken from another car and installed in my 4A and the pinion is too long?
It's the last hurdle to getting my car back together... All help is greatly appreciated!!! Thank you!!!
Here is a photo of my 4A to compare, fits fine under the plastic cover although the bolt along that curve is a tuffy w or w/o the speedo drive.
That was my experience several years ago when I installed the OD on my 4A. I cut an access panel and fabricated a cover using the cutout material and aluminum flashing. Also if you have a factory workshop manual, figure 6 on page 2-304 shows a cutout to access the solenoid operating lever. I fabricated this opening and cover as well, and very glad I did as several adjustments were required post install.
That picture makes a whole lot more sense to me. My car has a much longer one, it sticks out at least an inch more.
Do you have a picture of yours? Do you have the access plate on that side of the gearbox cover? I thought it was needed to clear the speedometer angle drive as well.
The major vendors sell new ones or you can keep an eye on eBay for used ones. Occassionally they come up at a reasonable price.
Scott
Don_R Spitfire Spit trans trouble Triumph 19
T General Tech Clutch trouble Triumph 12
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
sparkydave Trouble running hot Spridgets 10
F General Tech trouble with editing post Triumph 2
HealeyRick Tach Trouble Spridgets 2
JPSmit Trouble posting pics FORUM Navigation Questions 2
D Tune Up Trouble Austin Healey 24
G TR6 Clutch trouble Triumph 4
J Powertune booster for a bj8 , trouble installing Austin Healey 2
T Trouble inserting pictures to post FORUM Navigation Questions 2
R TR6 Trouble with TR6, carb now??? Triumph 6
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
C First Gear Trouble BN1 Austin Healey 5
L Trouble refitting pulley to new water pump Spridgets 9
C bugeye trouble spots Spridgets 5
C what are the trouble spots on a bugeye Austin Healey 1
RickB MGB Trouble bleeding new clutch MC & slave MG 6
B sprite engine trouble? Spridgets 2
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
R Lower wishbone bushing installation trouble Austin Healey 9
F MGB '76 MGB ignition trouble MG 62
S Electrical Trouble Shooting Spridgets 8
longbridgehealey Big trouble with BN4 brakes Austin Healey 53
MG Lily T-Series MG-TD Battery Trouble? MG 4
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
smaceng TR6 Trouble with a TR6....body! Triumph 10
bighealeysource Trouble getting toe in done on BN2 Austin Healey 16
J Having trouble getting Forum to work on IE 9 since it was switched to the new format. FORUM Navigation Questions 7
P Flasher trouble shooting - pls help Austin Healey 6
Morris I could be in trouble here... Spridgets 17
M Another Ebay trouble child? Spridgets 39
glemon Trouble Lights for Cheapskates Like Me Restoration & Tools 3
TulsaFred First start trouble rebuilt 1275 Spridgets 29
dvmmatt steering trouble Spridgets 17
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
H Trouble shooting gas gauge...any hints? Austin Healey 9
S trouble shooting not working speedo or testing one Triumph 22
theleisure Trouble Dropping Motor into Mounts Spridgets 14
T Trouble restarting after a drive Spridgets 11
G Sway bar mounting area trouble? Spridgets 14
G DCOE trouble/qusetion Spridgets 10
M Had trouble with Prestone Power Steering Fluid? Jaguar 2
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
Tremelune Starter trouble--Local lifetime replacment? Spridgets 54
R engine trouble, need advice Spridgets 16
smaceng Engine Trouble? Spridgets 7
G Trouble getting flywheel ring gear on. Spridgets 23
RickB MK2 Sprite - new windscreen to body seal - trouble Spridgets 21
P Transmission trouble Austin Healey 14
