TR2/3/3A Tropical metal fan for TR3
GerryL
I believe that I have a metal tropical fan. There are four oval shaped mounting wholes. When placed on the fan hub only two of the four holes can be aligned. Is it necessary to drill two additional wholes in the hub to mount the fan?
I forget what that's off of (Volvo maybe), but it's not an original Triumph "tropical" fan. So yes, if you want to use it, you'll need to drill the extra holes. Preferably with some accuracy, so the fan doesn't run off-center.
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
TomMull TR2/3/3A Tropical fan, I wonder what I bought?? Triumph 2
TomMull Wanted Tropical fan for TR3 Triumph Classifieds 8
T Let's talk tropical fans... Triumph 1
M GT6 TR3 GT6 Tropical fan Triumph 17
T BCF Tropical Dinner Tonight! Triumph 18
6 Moss Recall: Tropical Radiator Fan Austin Healey 46
B Is the rear edge of the Bugeye bonnet sheet metal supposed to be bent inward? Spridgets 2
G For Sale TR3 original metal air filters Triumph Classifieds 0
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
D Made a sheet metal break. Restoration & Tools 5
J Door Draught Metal Clips Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
F Off Topic metal forming for a friend Triumph 25
N Spridget sheet metal Spridgets Classified 0
steveg TR6 Metal Dash - does anyone make one? Triumph 13
J For Sale Triumph TR 2/3MISC sheet metal parts Triumph Classifieds 1
Busted knuckles TR2/3/3A Sheet metal question, Triumph 5
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
F TR2/3/3A Rear sheetmetal repair Triumph 73
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
S TR2/3/3A busted through to bare metal Triumph 18
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
SpeedyG TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
S TR2/3/3A were the 2 metal gas lines connect Triumph 18
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
S TR4/4A Metal facia trashed Triumph 3
R metal adhesives Austin Healey 12
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
C Recommendations on where to send my 1954 BN1 for metal work? Austin Healey 13
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
I General TR Pot metal rechroming Triumph 7
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
MTribe TR6 Can you identify these metal shavings in the oil? Triumph 32
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Brinkerhoff MGA metal work details MG 18
X sheetmetal needed Spridgets 1
certifiedcarnut Spridget master cylinder cap, metal Spridgets 8
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
Scot1966 TR6 TR6 sheet metal Triumph 3
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
