Triple carb setup too rich? How to adjust?
Fellow Healeyites,
I have a triple carb setup on my 63 BJ7. It consists of three manifolds bored out to 1 3/4 inches with 3 HS6 carbs.
I have BC standard needles and red 4.5oz spings as recommended by www.ahc-midlands.org.uk for their triple carb modifications. The choke is off but my plugs keep fowling. I have NGK BPR5EGP plugs. Maybe they are too cold???? I also have a facet fuel pump with no in-line regulator. Maybe I need a regulator. I adjusted the chokes repeatedly to no avail. Now I think that I will double check the float levels. Could the float levels be too high? Also, with these mods what should the gap be for the needle and seat assembly. Thanks!
Take the Dashpots off and with the ignition turned on look to see if petrol is overflowing from the main jets. If it is and the HS6 carbs are the ones with nylon floats you need to take off the lids, invert them and make sure the clearance between the ridge on the lid and the nylon part of the float is 1/8".
If the gap is correct and the flooding continues, replace the needle assemblies with these
https://www.moss-europe.co.uk/Shop/ViewProducts.aspx?PlateIndexID=18415
You can check what the fuel pressure should be from the www.burlen.co.uk site and also the relationship between needles.
The manufacturers all used to set the cars up with the main jets 35-38 thou below the jet bridge.
I hope this is some use.
Ash
When you say that the plugs are fouling, are you starting to lose spark in the cylinders? IE. dropping down to 5 then 4 etc. My car burns oil so you can't get worse fouling than that. With cool plugs ( some idiot guided me to a new set ) the cylinders just fell away one by one. Replaced them with a new set after finding out all about hot and cool plugs and the problem disappeared.
:cheers:
Bob
I think that I fixed it today. I removed the dashpots as recommended, turned the key and wittnesses a gushing spout of gasoline shoot 2 feet into the air from #1 carb. I installed a pressure regulator, new float needle on #1 carb and a different float bowl lid on #1. I think that it was the float bowl lid. The one I had on had three brass fittings. One overflow, one inlet, one outlet. It was not supposed to have the overflow. The one I installed did not have an overflow. Seems to work fine now. We will see if my plugs foul but I doubt it. Thanks!
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
davidb BT7 triple carb question Austin Healey 15
B triple carb needles? Austin Healey 2
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
Brosky Goodparts Triple Carb Heat Shield Triumph 16
D triple carb conversion Jaguar 3
D Triple Carb Intake Triumph 8
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
hondo402000 Goodparts Triple Carb manifold for sale Triumph 0
G TR6 Question for TR6 triple carb owners Triumph 21
tony barnhill Triple-Carb Interchanges [was "Dumb Question"] Austin Healey 2
S Richard Goods Triple Carb intakes. How good? Triumph 18
A Triple carb set-up Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
G Triple Weber DCNFs on 280i V6? TVR 1
H Triple Weber 45's Tipp? Austin Healey 2
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
Simmo TR6 Triple Webers on TR6 Triumph 7
J Triple Webers Austin Healey 19
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
M TVR 2500M Triple Weber 40 DCOEs TVR 130
S Tuning Triple SU's Jaguar 6
1 07 Triumph Daytona 675 converted to Street Triple British Motorbikes 5
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
B Spridget Triple Master Setup Racing 5
B Brake union Switch Triple Master HELP!!!! Racing 5
B performance increase from triple strombergs?? Triumph 33
Trick6 Triple Stromberg Needle Size Issues Triumph 9
G Modifying the triple intake choke/throttle setup Triumph 18
hondo402000 vacuum advance for triple webers Triumph 2
MadRiver High praise for Triple C Triumph 5
L triple SUs Jaguar 1
D Triple Strombergs Triumph 15
T Triple Whammy for Crypty & Pedro Triumph 12
B Air Filters for Triple Webers, BT7 Austin Healey 9
Brosky Choke cable question on Triple ZS setups Triumph 6
Brosky All the pics for Micropolish Triple Carbs Triumph 7
Brosky New project, triple carbs, micropolished complete Triumph 21
S Triple Strombergs or Triple Webers Triumph 15
M 69' E-Type triple SU conversion Jaguar 5
hondo402000 Goods parts triple cars manifold for sale *DELETED* Triumph 26
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
G Triple Stromberg throttle linkage Triumph 12
G triple zs air filters - any ideas? Triumph 4
G TR6 Anyone running triple ZS on a TR6? Triumph 6
DerekJ Triple SU's Jaguar 2
TR_JOE250 TR5/TR250 Need info for fitting triple ZS carbs to TR-250 Triumph 7
DerekJ Triple 3/4" SU's HD6 Austin Healey 12
