TR6 TR6 Heater Case/Core/Motor Repair 101
Brosky
Here ya go! All you ever wanted to know about the hard to get at TR6 heater case and what really lurks inside the beast. I included pictures of all of the now NLA parts and the proof of how I actually got lucky for a change on ebay.
https://www.74tr6.com/heater.htm /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Great information and good pictures on you link. Do you know what the purpose of the foam is? Thanks. Daniel
Good pics, Paul. Actually, the heaters were all originally screwed together with those little-bitty sheet metal screws. If you found one that has rivets, it has been overhauled. I pop-riveted mine back together, primarily because I used non-traditional foam padding inside and the whole thing ended up rather tight to re-assemble. Hence, rivets were stronger for me.
Good posting, well thought out, good wording. You must be in the business.
Looks just like the one I pulled out of my TR4A.
Had a huge mouse nest sitting on top of the fan; they had 18 yrs to construct it !
I figured the foam was to seal the housing where it fits into the cowl vent. Mine was screwed together; I had to use a cut off wheel to remove all the rusted ones.
Put it back togethet w/ S/S screws..
Good luck
Thanks, Bill. I think that you know I was in the business for 25 years, so reading service manuals was a way of life and writing procedures for things not in manuals was my job, when I got to management levels, so here we are.
I will post the results of the pressure testing and I'm hoping the rad shop will allow me to take pictures of the process. Some of the things those of us who have been around for awhile take for granted need to be shown or explained to the next generation behind us.
I plan to clean this one up and paint if needed, but I don't think that it will need much. I want to stop at the local hobby shop and get some foam with tape on one side to seal the case as well as to insulate the core. What's there will probably get ruined during the testing process.
I did order the new bulkhead seals and the mounting kits from TRF. I'll post what actually comes with the kits as I reassemble the case.
Now you have me really thinking about the other case that I have. I wonder if it's better inside than this one? This weekend will be drill out rivet time.
Films at 11...........
D Wanted TR6 Lamp/Bezel Assembly - Heater Controls - 219139 Triumph Classifieds 1
TR3TR6 TR6 Triumph tr6 heater motor Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
D TR6 76 TR6 Heater/Blower Switch Triumph 1
B TR6 TR6 Heater core plugged? Triumph 9
W TR6 installing heater hoses '74 tr6 Triumph 1
I TR6 Si sealant for TR6 heater box? Triumph 1
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
I TR6 TR6 heater removal help please. Triumph 5
Brosky TR6 TR6 Heater Valve - EXPOSED Triumph 9
I TR6 Help with rebuilding TR6 heater system please Triumph 19
I TR6 TR6 heater fire Triumph 15
bigbadbluetr6 TR6 TR6 Heater Triumph 14
hondo402000 TR6 New Heater valve installed from Parts america TR6 Triumph 4
J TR6 Tr6 heater assemblies Triumph 8
bcbennett TR6 TR6 Heater Fan question Triumph 9
WidespreadPanic TR6 Disable Heater on a TR6? Good idea? Triumph 10
I TR6 TR6 heater suggestions Triumph 8
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
O TR6 Pressure testing a TR6 Heater core Triumph 16
T TR6 tr6 heater motor wanted Triumph 13
A TR6 TR6 heater fan conversion?? Triumph 5
A TR6 TR6 heater hoses. Triumph 1
I TR6 69 TR6 heater control cable Triumph 6
V TR6 TR6 Radiator and Heater hoses Triumph 8
RomanH TR6 TR6 Heater function Triumph 12
Brosky TR6 TR6 heater fan switch replacement Triumph 7
AltaKnight TR6 TR6 leaky heater valve Triumph 2
Webb Sledge TR6 TR6 Heater switch Triumph 2
G TR6 Removing heater from my TR6...... Triumph 14
H TR6 tr6 heater motor resistor Triumph 0
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
M TR6 TR6 heater box arm Triumph 4
A TR6 TR6 Heater Control Question Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
P TR6 72 tr6 heater blower Triumph 2
S TR6 replacement switch for TR6 heater fan Triumph 5
A TR6 TR6 Heater Problems Triumph 5
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
E TR6 TR6 Front fenders Triumph 5
EWD TR6 74 TR6 headscratcher Triumph 38
jfarris For Sale TR6 Yellow Fan - New Triumph Classifieds 0
tr6nitjulius TR6 TR6 review Triumph 3
K TR2/3/3A First gear ratio on the TR6 gearbox? Triumph 11
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 2
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
T TR6 TR6 distributor issue Triumph 6
