TR2/3/3A TR3 Fuel Gauge Sending Unit
CaptRoy
I ordered a sending unit for my fuel gauge from Moss and when I went to change it tonight I noticed the one on the car had two wires running to it and the new one only had a place for one.
Has anyone changed one out?? Should I call them to verify the right part?? Are they good to work with??
Thanks
Hey Roy,
Moss is good to work with, no problem. They are usually pretty knowledgeable about what they sell. Call them...
Bill
Re: TR3 Fuel Gauge Sending Unit - Update
I talked with Moss today and the tech support was great.. We resolved the two wire issue and tracked it down to the gauge as it read the same with both sending units. I'm sending the gauge and sending unit off to Mid Valley Instruments to have the gauge rebuile and sending unit calibrated to the gauge.
So why the extra wire you may ask. Seems the PO put rubber insulators on the tank preventing it from being a ground. He wired a ground from the frame..
Thanks for the input...
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
martx-5 TR2/3/3A TR3 Fuel Gauge Triumph 17
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
martx-5 TR2/3/3A TR3 Fuel Gauge Calibration Triumph 13
S TR2/3/3A Tr3 fuel gauge sending unit Triumph 6
P TR2/3/3A TR3 Fuel Gauge Triumph 4
Geo Hahn TR2/3/3A TR3 Fuel Gauge Triumph 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
D TR2/3/3A tr3 fuel line Triumph 9
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
S TR2/3/3A old tr3 fuel pump Triumph 2
S TR2/3/3A TR3 fuel pump Triumph 16
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
M TR2/3/3A TR3 fuel pump Triumph 14
O TR2/3/3A TR3 Fuel Tanks Triumph 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
S TR2/3/3A tr3 fuel delivery system Triumph 18
M TR2/3/3A TR3 fuel cap install question Triumph 9
S TR2/3/3A tr3 metal fuel lines Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
M TR2/3/3A TR3 fuel line part#104842 Triumph 5
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
T TR2/3/3A TR3 weeping at fuel pump, again Triumph 11
J TR2/3/3A TR3 fuel pump question Triumph 7
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
J TR2/3/3A TR3 Fuel line size Triumph 3
mgedit TR2/3/3A Seal for TR3 Fuel Tap Triumph 10
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
S TR2/3/3A Tr3 Fuel line support clips Triumph 4
T TR2/3/3A make fuel line from tank to a 90 degrvTR3 Fuel ine Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
M TR2/3/3A TR3 Fuel line routing Triumph 6
M TR2/3/3A Fuel line missing [ TR3] Triumph 13
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
mrv8q TR2/3/3A TR3 Fuel line Q Triumph 4
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
T TR2/3/3A Visiting the tr3 fuel tank again Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
