TR2/3/3A Tr3 fuel filter
prb51
Gents, I have a 56 Tr3 and the old fuel hook ups to the carbs. The metal encased lines with the bolted attachments. Suggestions as to a good location for an inline filter. Has anyone cut the woven metal/rubber lines and added one there with success? Thanks
Let's see... 56 should have the shutoff valve on the frame by the fuel pump. Best spot would be between that valve and the pump. There should be a rubber line right there to tap into, and that will trap any crud before it gets into the pump.
Personally, I do not use an inline filter. That bronze screen above the fuel pump catch jar traps any fuel tank crud, stuff small enough to get thru that doesn't seem to be a problem.
Of course if you are running an electric pump or non-stock carbs your needs may differ.
I still think I'll put a modern inline unit in just to be on the safe side. I'll check on that location too.
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
T TR2/3/3A Fuel filter madness on the TR3 [holy cow] Triumph 11
RedTR3 TR2/3/3A TR3 Fuel Filter Triumph 6
RedTR3 TR2/3/3A Fuel Filter TR3 Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
D TR2/3/3A tr3 fuel line Triumph 9
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
S TR2/3/3A old tr3 fuel pump Triumph 2
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
S TR2/3/3A TR3 fuel pump Triumph 16
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
M TR2/3/3A TR3 fuel pump Triumph 14
O TR2/3/3A TR3 Fuel Tanks Triumph 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
S TR2/3/3A tr3 fuel delivery system Triumph 18
M TR2/3/3A TR3 fuel cap install question Triumph 9
S TR2/3/3A tr3 metal fuel lines Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
M TR2/3/3A TR3 fuel line part#104842 Triumph 5
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
T TR2/3/3A TR3 weeping at fuel pump, again Triumph 11
J TR2/3/3A TR3 fuel pump question Triumph 7
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
J TR2/3/3A TR3 Fuel line size Triumph 3
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
mgedit TR2/3/3A Seal for TR3 Fuel Tap Triumph 10
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
S TR2/3/3A Tr3 Fuel line support clips Triumph 4
T TR2/3/3A make fuel line from tank to a 90 degrvTR3 Fuel ine Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
M TR2/3/3A TR3 Fuel line routing Triumph 6
M TR2/3/3A Fuel line missing [ TR3] Triumph 13
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
mrv8q TR2/3/3A TR3 Fuel line Q Triumph 4
martx-5 TR2/3/3A TR3 Fuel Gauge Triumph 17
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
T TR2/3/3A Visiting the tr3 fuel tank again Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
R TR2/3/3A TR3 Fuel delivery problem Triumph 5
