Well I am asking questions about the fuel delivery system of a tr3 that i thought I knew the answer too. Anyways my 58 tr3 started fading out like it was out of gas, but I just filled it up. I check the pump by unhooking the line and the pump provided just a weak pump. I started to take the pump off, but when I undid the feed line only dribbles of fuel come out? Should there not be a stream of fuel coming out by gravity? Now I am thinking the line from the tank might be partially blocked. Anybody have any suggestions. I do not want to pull the pump if that is not it. The bowl on the pump is full and the float bowls have fuel.
