Tiger project , phaze zero
Bob Claffie
Here are a couple pics of my NC Tiger after it finally arrived in Ma 9 months after purchase ! Planning on a two year project, if I get lucky. Probably have to learn to weld one of these days. Car is pretty solid underneath but the floors are whipped.
If there is any interest I'll keep posting , but slowly as I don't expect progress to be rapid. Bob
thegoodbeamer
Hi Bob
Looks like you have some work ahead of you.
Its the journey and not the speed so enjoy
Once in awjile let us know howits going
drooartz
Would love to see more pictures as you progress. Lots do do there, but should be a good project.
MikeP
No, details say MK1A, the headlamp rims seem to match the color and general condition,
side moldings and inside screw tail lamp lenses. None of these are MK2. I'd guess the sunbeam
script on the hood was someone else's later add on.
Bob Claffie
Bob Claffie
Right on Mike, it is an early Mk1A built in late '65. Someone has "upgraded" it to a 289 engine but that's as close to a MK2 as it will get.
This one has been cut up in the front. They had a bad (unearned) rep for overheating way back when and this one has an oversize radiator jambed in it along with an elec fan. I hope along the way to put it back to what it should be. The car came with the original radiator and shroud included so I'm part way there.
I had an original Mk1 back in '65 that I put a 289 in and never had a cooling problem. At the time I was big into autocrossing and coincidently our family car was a '65 Mustang. Swapped the engines while my company was on strike for a week ! Bob
Bob Claffie
Bob Claffie
Yes, the hood has a non functional scoop, possibly used for clearance, although it now has an original size 2 bbl carb. Also has holes showing on the inside of the hood (only) for long gone hood pins. Has the top of the firewall butchered up from the previously mentioned hood pins.
Bad joke department. Spent most of the last week trying to fit a window regulator to the drivers side from a spare door that came with the car. Finally got it in this after noon only to find the replacement is also broken !
If anyone has a decent trunk floor they are not planning to use please give me a shout. Thanks, Bob
MadRiver
Bronze
Hi Bob:
If you've never owned a Tiger before, you're going to love it. Such wonderful machines in every way, shape and form, with the exception of lots of fussy details courtesy of Lord Rootes. I've got an early Mk 1, so some things won't be the same, but if you ever need photos of anything, please let me know.
Bob Claffie
Bob Claffie
Bill, I'm going to take you up on that picture offer. This car has a non-original dash in it now and a lot of wiring behind the dash is red and red and red. There is a lot of "customization". I have a repro dash minus the veneer (yet)and a replacement wiring harness so at some point I'm going to replace the dash and rewire it from scratch, BUT I have no idea how things behind the dash are laid out ie: heater mechanism, where the various cables run etc.
I have the shop manual but it doesn't touch on the DETAILS very well at all. After that phase the engine compartment will need sorting out. Most everything is there but not necessarily where it should be. This piece will be down the road a ways. I have budgeted two years and at this point expect I will need all that and then some. Thanks, Bob
MadRiver
Bronze
Hi Bob:
It would be my pleasure. My car also has a replacement dash installed by the prior owner, but from photographs, it seems that everything is in the right place (though it should all be labeled with neat white letters, which is lacking on mine). I may have a few photos of some friends' cars with original dashboards that I can dig up for you as well. Also, bear in mind that some minor things changed from the Mk I to the Mk Ia, but aside from the fuel pump location and the replacement of the metal lids that cover the top when its down (with much a more sensible traditional cloth cover), I'm not sure what else may be different.
Best,
B.
Bob Claffie
Bob Claffie
Hi Bill, found another semi-useless question. What holds the heater controls to the back of the dash? I have part of an Alpine dash and it looks like there were bosses molded into the back of the plastic dash. Since I didn't remove the original dash I don't have a reference. Thanks, Bob
MikeP
Three metal brackets that went on over the studs for the heater control cover. Center one had 2 arms, one to each side. Outer ones had one arm, each pointing towards the center. Easy to make, Just center the controls in the slots and use bits of cardboard to make patterns flat againdst the dash for the studs and bent out over the controls. Bit of 20 gauge sheet, some work with the snips and drill for the holes, bend 90 degrees and you're done.
BTY, there should also be a flat piece on the ignition switch to keep it from rotating went the key is turned, in case you're also missing that.
MadRiver
Bronze
Hi Bob -- Let me see if I can get some photos and send them to you. Can you send me a PM with your email address?
Just to keep you inspired, I fired up our Tiger over the weekend -- I hadn't taken her out since last fall. She started right up and she rattled all the windows in the neighborhood! Mwahahahahahaha! :devilgrin:
Bob Claffie
Bob Claffie
Hit a milestone today. Pulled the plugs and oiled up the cylinders and went at it with a new battery. After about a minute or two(seemed like forever) the oil pressure popped right up to 60 lbs with no peculiar sounds. No idea last time the engine fired but it was longer ago than 2000 so I am very happy at this point. If I can jury rig a fuel supply I may try to fire the engine later in the week.
Bob
K
KSIS
Bob,
I am picking up a MK1 Alpine sometime next week. The gentleman also has a garage full of parts from another car he stripped. The MK1 is pretty far gone body wise but all is there. Let me kno what you may need. I'll send pics when I get it.
Bob Claffie Tiger project, phaze one Sunbeam (Rootes) 5
Grantura_MKI For Sale Sunbeam Tiger Other British Classifieds 0
D 1965 Sunbeam Tiger featured on my YouTube channel Sunbeam (Rootes) 0
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
D For Sale 1965 Sunbeam Tiger Other British Classifieds 2
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
T Wanted Early Tiger or Sunbeam hardtop Other British Classifieds 0
David Townsend Alpine/Tiger Limited Edition Prints Sunbeam (Rootes) 0
Grantura_MKI Tiger at Amelia auction Sunbeam (Rootes) 12
aeronca65t Tiger-LeMans at Goodwood-2013 Sunbeam (Rootes) 1
EricG Tiger/Daimler SP 250 Comparison Test Sunbeam (Rootes) 1
G Original Tiger barn find for sale Sunbeam (Rootes) 1
bighealeysource Nice 66 Tiger for sale Sunbeam (Rootes) 1
A Tiger in a video Sunbeam (Rootes) 1
HealeyRick The Tiger Sharpens its Claws Sunbeam (Rootes) 2
Grantura_MKI Tiger on TV Sunbeam (Rootes) 1
aeronca65t Tiger @ Watkins Glen Sunbeam (Rootes) 1
jfslenes June 30, 2011 Ebay Tiger = Awesome! Sunbeam (Rootes) 0
M Tiger with 302 engine Sunbeam (Rootes) 8
Steve Sunbeam Tiger... Which one? Sunbeam (Rootes) 12
jfslenes August 27, 2010 - 2 Tiger Race Cars on Ebay Sunbeam (Rootes) 0
G Saw a Red Tiger yesterday in Slidell Spridgets 9
S More Alpine and Tiger race car ads Sunbeam (Rootes) 3
aeronca65t Tiger-$3400 Sunbeam (Rootes) 4
S Sports Car Forum Tiger - ad from the 60's Sunbeam (Rootes) 7
aeronca65t Tiger Spotted Sunbeam (Rootes) 1
philman Autocrossing a Tiger Sunbeam (Rootes) 2
R New Tiger & Alpine? Sunbeam (Rootes) 16
S My Tiger Sunbeam (Rootes) 3
aeronca65t Merlin's Tiger Sunbeam (Rootes) 2
S Sunbeam Tiger Prices Sunbeam (Rootes) 2
aeronca65t Race Tiger Sunbeam (Rootes) 9
Bob Claffie Sell me your spare Tiger Sunbeam (Rootes) 0
philman Don Adams Tiger? Sunbeam (Rootes) 2
PAUL161 Sunbeam Tiger Engine Sunbeam (Rootes) 12
jfslenes SCCA Mag Suggests a Tiger in GT2 for 2007 Sunbeam (Rootes) 0
R Tiger Frame Sunbeam (Rootes) 6
F Trade Shleby GT350 for a Nice Tiger? Sunbeam (Rootes) 0
R Tiger trim rings Sunbeam (Rootes) 4
MadRiver Tiger fuel pump question Sunbeam (Rootes) 2
F How to build a fake Tiger? Sunbeam (Rootes) 11
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Steve Tiger Workshop Manual Sunbeam (Rootes) 0
MadRiver Tiger 1 Map light question Sunbeam (Rootes) 2
MadRiver Looking for photos of Tiger dashboards Sunbeam (Rootes) 2
beaulieu cost of new windshield for for Sunbeam Tiger ? Sunbeam (Rootes) 1
MadRiver Help Me Tiger Experts: Thoughts on this car? Sunbeam (Rootes) 2
C Replacement Shocks for a Mk1A Tiger Sunbeam (Rootes) 0
petervisor Tiger in Shelby Club Event at Sears Point Sunbeam (Rootes) 2
petervisor Tiger at Sears Point raceway Sunbeam (Rootes) 1
