thrust washers
BOXoROCKS
I am helping a friend with his TR6, very long story short. Is it at all possible that losing the thrust washers could cause the starter to fail to engage. Believe me we have covered all other bases and then some.
The thrust bearing thicknesses for the TR6 are about .100". If both fell out, the end float on the crank would be a little more then twice that...but, the would be movement both forward, which mean the starter pinion would be engaging MORE, and rearward, in which case the pinion would engage less. Normal starter pinion engagement is probably around 5/16"-3/8" (.312-.375) from all the starters I've seen here at work. If you subtract that .100" you will still get some engagement unless the starter pinion and flywheel gear is badly chewed up.
If you lost your thrust washers, that should be easy enough to check out by prying the front pulley back, and having someone then push in on the clutch. If those thrust washers aren't there, you will see about .200" movement...almost a 1/4". /bcforum/images/%%GRAEMLIN_URL%%/shocked.gif
Are you hearing any grinding noise whaen you go to start the car?? What are the symptoms?? Did you check all of the flywheel teeth?? You can see them by removing the plate at the bottom of the tranny and having someone turn the engine from the front.
Edit: I don't know if you started this saga in another thread, but if you did, please cite it, or list all of the bases that you did cover.
a new one on me after 35 yrs,ring gear spinning on the flywheel. not loose to the touch,but not tight enough for a starter to spin the engine. there is no end to wierd crap a brit car can do.
That's a very unusual circumstance, but not unheard of. The ring gear is a press/shrink fit that generally doesn't give any problems. The only time I've seen it happen is if the ring gear cracks. You're most likely in for another flywheel with ring gear, as when that gear starts spinning on the flywheel, it most likely ground some of the surface where the press fit is. I wouldn't trust putting a new ring gear on that.
Isn't that a lovely design...having the trust washers drop in the pan? Been there done that...arrrrrr!
Cheers, David.
KVH General Tech Thrust Washers Triumph 2
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
J TR6 Thrust washers in sump Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
P those infernal thrust washers Triumph 11
H Crankshaft Thrust Washers Austin Healey 2
O Spitfire Spit 1500 Thrust Washers? Triumph 13
6 thrust washers & cam Triumph 7
K TR2/3/3A TR3 thrust washers wishbone arm to trunnion ? Triumph 6
M pining the thrust washers on 1500cc Spridgets 10
Brosky Thrust washers, via Scott Helms and my way Triumph 8
2wrench Checking the thrust washers.....Dale? Triumph 3
Brosky TR6 Serious Thrust Washers for TR6 Triumph 24
B Sealing block and good thrust washers Triumph 5
floyd TR6 75 tr6 thrust washers Triumph 18
guzzul When thrust washers go bad Triumph 11
hondo402000 TR6 Triumph TR6 thrust washers Triumph 2
T Thrust Washers for Crypty Triumph 34
Tinkerman TR2/3/3A Crankshaft thrust washers, 60 TR3 Triumph 6
kaz2be Thrust washers Triumph 6
71tr Thrust Washers Triumph 2
G TR5/TR250 TR 250 thrust washers Triumph 2
B TR6 Thrust face repair Triumph 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
B TR4/4A Thrust washer issue Triumph 11
JPSmit Midget Thrust bearing coonversion Spridgets 9
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
K Thrust washer Austin Healey 4
PeterK Wedge TR7 thrust washer Triumph 0
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
H 4.2L distribitor drive distance/thrust washer Jaguar 0
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
Monark192 MGB MGB Diff Thrust Washer Question MG 2
S Tachometer thrust button Austin Healey 1
T ever see a rusty thrust washer? Triumph 10
T crank thrust bearings Triumph 5
TR6oldtimer TR6 Worn Thrust Bearings TR6 Triumph 26
Jim_Gruber Wheel Bearings and Thrust Label Spridgets 6
healeyboz replacing a thrust bushing Spridgets 6
M Layshaft thrust washer dimensions MG 1
B 1500 thrust washer Spridgets 10
JPSmit 1500 thrust bearing question Spridgets 10
Moseso Thrust Washer Dimension Question Triumph 3
2wrench Let's talk about the dreaded thrust washer wear. Triumph 8
B Pinning 1500 Thrust Washer Spridgets 3
Brosky Thrust Bearing Issue Triumph 22
tomshobby thrust bearings Triumph 1
hondo402000 TR6 TR6 thrust washer question Triumph 3
davidk Thrust Washer Questions Triumph 3
