TR6 Thinking of buying this TR6
Webb Sledge
I'm thinking about buying a TR6 from a friend of mine whose had it for a couple years, and is tired of putting money into it. He had put $3,000 into after he bought it for $8400. He is selling it for about $6000. It has never been restored though, and needs the following things mechanically: It has had 2 bent rims which have been unbalanced, causing it to need a new trailing arm, which I can get for free from my boss. It also needs 2 new rear rims. The front and the back tires/rims need to be aligned, and may need some minor front suspension work. We guess that the engine currently has about 50,000 miles on it, and could probably use a rebuild, but doesn't have to have one. My boss says that engine rebuilds are good for about 70,000 miles before it needs another one. The engine runs perfectly fine and smooth, but isn't making as much power as it could. I work at an LBC shop, so there would be no labor fees, as I would be doing the work myself with the guidance of the head honcho. This car I'm looking at is excellent cosmetically, the interior is great, and has only very minor surface rust in a small spot in the engine compartment. Nothing major is wrong with it, and I get the peace of mind of knowing that most of the major crap has been ironed out of it buy the PO. Below are some pictures of it from last fall. Needless to say, the engine compartment isn't nearly as clean, but the exterior paint is still just as good. Would you buy it, assuming you were looking for a TR6?
Think I'd consider it even if I weren't looking for a TR6. Love that particular green. Looks like a lot of fun for $6K.
The only thing I'm worried about is starting a minor engine rebuild, and then finding out it needs $2000 worth of parts and machine work. My boss said a "minor" overhaul would cost about $500 in parts with me doing all the work.
It looks very nice and the price seems very reasonable. I spent about a year and a half trying to find a good car at a decent price and finally paid a little too much for the spitfire mostly because I was tired of continually looking for a car. Your boss should be able to give you very good guidance on finding a good car. Good luck making the decision.
Is the under-bonnet pic a mistake? Looks like you have a TR6/250 hybrid.
I've spent the last couple years looking for the right TR6 for me. With my shopping expierence,... I'd say this car, for $6,000 would be a no brainer. I've looked at
$7500-$8500 cars that were not even close to the car you describe.
Does it have overdrive?
[ QUOTE ]
[/ QUOTE ]
I'd guess he got them mixed up... Look at the grille in the engine bay photo. That's a TR250, not the TR6 shown in the photo above.
Kurtis
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Kurtis
[/ QUOTE ]
Good catch........you are perfectly correct, these are pictures of two different cars. Could be an honest mistake by the seller. Could be. Webb, how well do you know this friend, and has your boss been able to take a look at this car?
Oops, I accidently added the wrong photo. I took these at a car show last year, and didn't know the titles to all of them when they came off the digital camera. My fault!
As to Stinky's question, no, it doesn't have overdrive, unfortunately.
Hi Webb How good a friend is he? What did he spend the $3,000. on. About 50,000 on the engine, does that indicate it had been rebuilt before? What is the milage indicated on the speedo? What is the frame like? Check out all the obvious bad spots, Trailing arm mounts, spring tower crossmember, how's the door fit. And yes, what about the engine compartment photo? If he is a good friend, he will tell you ALL and then let you make the decission. Good luck. Brian
I know this guy well. He went to my church for a long time, and now works with me, and I ride in that very TR6 to work every Saturday, because he picks me up. I've spent a fair amount of time in and around it, and from what I see it looks good. My boss is giving it a once over today, and then is gonna get back to me as to what condition its in and what it might need.
B thinking of buying a 1967 triumph 2000 Triumph 22
M Thinking about buying a 52 MG TD Spridgets 2
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
Bruce_B Spitfire Thinking of buying a 1969 Spitfire...but..... Triumph 8
RobT Thinking of buying a Lotus Europa S2... Am I nuts? Lotus 9
S Thinking of buying a 1960 Austin Healey- Questions Austin Healey 6
D MGB-GT Thinking of Buying a '67 MGBGT MG 8
t8nwa thinking of buying a classic - what to look for? British Motor Corp 2
Basil Thinking about buying a Mini British Motor Corp 18
JPSmit Thinking about Solenoids Restoration & Tools 2
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Healey Nut What were they thinking Austin Healey 12
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
bugedd Thinking about winter time projects Spridgets 5
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
TRMark TR2/3/3A Thinking of a TR 2/3 ratrod project Triumph 23
R TR4/4A Thinking About an Electric fan Triumph 10
tinman58 TR2/3/3A Bad thinking? Triumph 25
jsfbond GT6 Thinking out of the box Triumph 2
danstr6 TR6 Thinking of selling my TR6 Triumph 4
G Thinking About My First Bugeye Spridgets 20
bugedd Thinking of some tunes.... Spridgets 10
Lukens Am I thinking right? Jaeger electric temp gage. Triumph 4
bugedd What am I thinking?? Spridgets 19
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
mailbox Wedge Thinking of parting with project TR7 Triumph 3
bugedd Thinking about learning bodywork/paint Spridgets 35
glemon Spitfire Thinking about a Spitfire Triumph 7
regularman Thinking about taking in another midget Spridgets 2
B Down shifting problems, check my thinking? MG 1
jlaird Been thinking - about time. Spridgets 4
JPSmit I'm thinking of a Vauxhall Viva Other British Cars 10
MadRiver Thinking of selling our C MG 9
M_Pied_Lourd TR2/3/3A I am thinking of installing this in my TR3A... Triumph 13
bugedd Thinking about rebuilding my ribcase Spridgets 16
T OT - I'm thinking about it... Triumph 14
G Thinking of getting a Triumph Triumph 24
M wishfull thinking? Triumph 10
jlaird Thinking out loud, comment pls Spridgets 6
SCguy Wedge Thinking of selling my TR8... Triumph 24
T Weather and Transportation - alternate thinking? Spridgets 43
philman I'm thinking of wood veneer Restoration & Tools 3
sparkydave Thinking about paint Spridgets 8
jhorton3 Thinking Of A Discovery SE7 Rover / Land Rover 5
C I'm thinking its the fuel pump??? Spridgets 13
QuickSilver MGA Thinking About An MGA MG 9
judow Just thinking stage now... Rover / Land Rover 6
P Thinking about getting an XK120 Jaguar 16
M thinking about body work at home Spridgets 19
T Thinking of rebuilding my front suspension Triumph 6
