SU Jet Centering Tool - A Worthwhile Investment?
mxp01
Some suppliers sell a jet centering tool. It appears one tool can be used in a range of carbs, but some carbs will need a separate, different size tool. These are a bit pricey ($25-29 plus shipping). Are these a worthwhile investment?
I don't believe they are necessary though someone with more SU experience than me might disagree. I've relied on feel when the piston is at the bottom of its travel.
Kurt.
If your working with the car you are referring to in the other post you don't need a centering tool
the ones with a spring are self centering.
D Jet centering tool Triumph 3
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
K SU's again...Jet centering? Triumph 7
Nelson SU jet centering Spridgets 11
J Spitfire SU Carb Jet Assembly Seized Triumph 1
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
Sopwith_Camel MGB jet leaver MG 2
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
torque-drive MGB SU HS4 jet height adjustments MG 6
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
K TR2/3/3A Unmarked SU jet needles? Triumph 3
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
S TR2/3/3A polish the jet Triumph 1
T TR2/3/3A H6 jet bearing seals Triumph 3
H BJ8 jet drop measurement Austin Healey 8
BillyB62 TR2/3/3A Carb Jet Triumph 8
M TR2/3/3A H6 Jet assembly leaks after rebuild Triumph 6
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
TomMull TR2/3/3A Wrong SU jet? Triumph 0
N Jet Hot??? Spridgets 13
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
sim HUS 2 main jet adjustment Spridgets 40
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
K TR2/3/3A SU carb...after jet centered...jet lever hesitation. Triumph 3
T T-Series Need new jet levers MG 3
D Jet seals Triumph 2
J Getting HS2 carb jet out Spridgets 11
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
Bremer Jet needle removal Triumph 7
jdubois What the heck is this jet needle? Triumph 8
K TR2/3/3A TR3 SU H6 Jet[Gland Packing] Rubber O RING Size? Triumph 3
K TR2/3/3A TR3A SU Jet marking .100 ? Triumph 6
G Who sells jet-to-bowl line? Spridgets 6
G Fuel hose replacement from bowl to jet Spridgets 4
doughairfield Jet Assembly sticking Triumph 6
R Jet Hot Coatings TVR 6
drooartz Jet-Hot headers came today! Spridgets 5
drooartz Jet Hot header coating questions Spridgets 13
H HS6 JET identification Triumph 2
G I called Jet Hot about my peeling SS headers... Triumph 20
G Jet Hot coating peeling off my headers........... Triumph 9
