I just finished getting an A OD transmission ready to use. Only now am I discovering that this transmission that I bought is an early "bullnose" transmission. All of my starters are for later cars. I'm looking at Nippodenso Hi Torque starters from BritishStarters.com I have a technical question that is giving them a little pause. I have a hodge-podge of parts. I am using a TR4a engine with a TR3a flywheel/clutch and (apparently) an early TR3 transmission. My question is: Is the ring gear tooth count the same on the press on ring gears for the early TR3 (with bullnose "bomb" Starter) the same as the bolt on flywheel for the TR3a and later cars? If it is I should be fine. I assume (maybe I shouldn't) that I can use the high torque starter with the bullnose transmission, as the pinion gear of the starter engages the ring gear by throwing the pinion away from the starter like the bull nose starter as opposed to the later TR starters which pull the pinion gear into the ring gear. I am I as clear as mud? Advice please
Joe ('58/'59) TR3A
Joe ('58/'59) TR3A
Hi Guest!
