GT6 Sometimes the plan doesn't come together.
trrdster2000
Hi all, the GT6 project has hit a little snag. The frame from the GT6 with all components from the GT6 donor are all but ready for the body. No where have I read about the Spitfire frame and the GT6 frame being so different in the rear. The '74 Spit has the extra frame member to give support for the tail end. Looks like it was added on with a slip fit and welded in place. We need to cut it off and give ourselves some extra, transfer the body and use the bolt holes that are there for the bumper to line it up, then weld it up. Not the worst thing, but just painful. The owner likes the big rubber front bumpers and the brackets are different on the '72 GT6, they need to be cut off and rounded a bit.
The gauges on the Spit are chrome and he likes that, minor change from black on the GT6 ones, but he also has a oil gauge that is chrome, nice feature. We will order the body panels for the rust areas tomorrow, but we are going to place it on the frame and let him enjoy the rest of the summer and fall and do the body work over the winter, that way we can also tweak all the little problem areas along the way.
The TR7 rims look good but we did have to grind the caliber a little. Sorry about the pictures not getting ready, he is having a hard time getting them off the phone. I'll get the wife to have a look see.
I know it sounds like a lot of work, but we are having a good time and his basement is air conditioned in this hot heat I could not think about doing it in my new garage, haven't had time to insulate and put in a climate control.
Come help when you can, Wayne
Andrew Mace
Hi all, the GT6 project has hit a little snag. The frame from the GT6 with all components from the GT6 donor are all but ready for the body. No where have I read about the Spitfire frame and the GT6 frame being so different in the rear. The '74 Spit has the extra frame member to give support for the tail end. Looks like it was added on with a slip fit and welded in place. We need to cut it off....
From what I've been able to determine over the years, the only real useful purpose of those 1974 and later "Federal" Spitfire frame extensions were to support the "impact" bumpers required. The tub was otherwise always able to support itself quite well at the rear without them. ;)
trrdster2000
trrdster2000
Thanks Andy for your support and thoughts. I was thinking along the same direction and a good friend told me to cut it off and he will cut all the welds. He said he had a very thin disk that was designed for just that purpose. We will see, as I am more inclined to use a angle iron and drill a couple of holes and do a little welding.
Other wise all is good. I would have like a better body, but this one will do.
I still want to do the Herald with this frame and engine if I can get it away from my buddy. I'll give him the whole thing if he will fix it himself, lets just get the little Herald on the road.
Thanks again, Wayne
Andrew Mace
Wayne, SOMEONE needs to just get the little Herald on the road. Period. THEN figure out if it "needs" to be greatly modified/updated. ;)
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
S Sometimes I wonder... Spridgets 3
JPSmit Sometimes it is better to be lucky than good Spridgets 15
L Turn signal problem solved [sometimes its not your fault] Austin Healey 6
JPSmit Sometimes I am surprised I am not dead Spridgets 15
Lukens TR2/3/3A Sometimes I wonder about myself. [TR3 related] Triumph 5
Rob Glasgow Sometimes it's just the small things.... Austin Healey 3
drooartz MGB Sometimes I'm very proud of my work... MG 6
Geo Hahn Sometimes ebay Makes Me Smile Triumph 14
T Sometimes it is the little things... Triumph 7
Newkie Car wont start sometimes MG 8
Jer sometimes smokey but not all the time... Spridgets 16
L TR6 Help needed with TR6 Spongy brakes [sometimes] Triumph 27
RickB Sometimes I wish I lived in England. Spridgets 30
JPSmit OT but sometimes it's better to be lucky than good Spridgets 9
T Sometimes it is the little things.... Triumph 12
cdsmith Sometimes its just nice to listen... Spridgets 12
ChrisS Sometimes it's best not to look... Spridgets 27
drooartz Sometimes we don't know how good we have it Spridgets 2
wangdango '82 XJ6 starts, then sometimes does not.. Jaguar 2
bugimike sometimes you beat the mountain and... Racing 11
N Carb sometimes sticks at a high idle Triumph 8
Luke_Healey Sometimes my car ownership timelines bunch up.... Spridgets 19
zimmy clutch....works sometimes Spridgets 10
T Sometimes it is the easy stuff.... Triumph 5
regularman Sometimes dreading a thing is more work than going Spridgets 1
dklawson Sometimes You Have to Be Juvenile British Motor Corp 15
jaybird Sometimes they find you MG 31
G Smoking like a chimney - but only sometimes Triumph 9
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
B A plan to replace BE floor pans Spridgets 0
R Our J-H plan - torque specs needed! Other British Cars 2
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Jer Winter repair plan[s] for my 74... Spridgets 9
drooartz Help me put together a plan for my Bugeye Spridgets 46
B Plan on rewiring a BJ7 with a new harness Austin Healey 12
L Roaster Factory Investment Plan Triumph 25
D Assembly Game Plan Triumph 19
T TR4/4A Pics of the new TR4a & a plan is hatched... Triumph 12
G New day and a new plan Spridgets 14
bugimike A plan comes together...for theliesure Spridgets 5
drooartz New specific plan for fuel pump install Spridgets 23
fabmandan Plan B Spridgets 5
regularman A plan to keep my sanity Spridgets 6
zimmy THE 7 STEP TOTAL PAINT PLAN Spridgets 18
N Rocker Repair Plan Triumph 22
jlaird Todays plan Spridgets 7
jlaird The Plan Spridgets 2
