TR4/4A Smiths Oil Temp Gauge
RJS
Hi
Has anyone ever mounted an oil temp gauge? I am looking at the Smiths BT2240-01C which is 52mm and if I can swap the chrome bezel it will match existing gauges.
The compatible temp sender is Smiths TT6811-01. It is 1/8" x NPT thread. Any ideas where it can be mounted?
Thanks
Bob
Thanks Mad Dog
Great idea. I have a modern radio in the glove box - which I NEVER use btw.
Any thoughts were to mount the sender? Could it be as easy as screwing into a port in the engine block? Or, would I need to weld a bung into the oil pan?
Bob
There is a gallery plug in the back of the head . Not sure why you want this critter, If you
have all 7.5 Qts in the pan , it is hard to get them all hot at once......
Mad dog
Hi,
I mounted a mechanical oil temp gauge under the bottom of the dash. The sending unit is about an inch from the drain plug. I dropped the pan and welded in a bung. In the summer-time around Baltimore MD, I would see 230-240F. When I installed a Supra 5 speed conversion, the oil temp dropped by 20-30F.
Good luck, Roy
If you were the type to go crazy here , why not get an alloy pan with finning to dissipate
excess heat? Doesn't help to just monitor the heat if your not able to correct it.
Mad dog
Mad dog
Oil Temp Gauge is just an indicator that your engine bearings are dying.
Thanks all for comments. No concerns here of running hot or any issues. Just simple curiosity on what normal oil temp would be. Roy, thanks for sharing observations on your oil temps.
Bob
Don’t do it. It will only cause worry.
too hot, too cold.
i fitted an ali sump with the boss for a temp gauge on my 3a. I should have just blanked it.
I fitted an oil temp gauge and it never gets very hot. I then started to worry about oil performance as everything you read says oil needs to be 80 to 120c
Mine happily sits at 60-70c
Just concentrate onthe pressure. That’s the important bit.
Thanks Hamish,
You may very well be right, best well enough left alone. I've had the car for 23 years with no oil issues. Was interested in "normal" oil operating temp to do exactly as you say - judge oil performance. Having said that, I've used the same oil and weight for years and get a consistent 65psi cruising at 2000RPM. So, better to not try and fix what's not broken.
Bob
The race car had oil issues due to the 3.5qt that the Mazda Mx5 held. The cooler is behind the
passenger side scoop with the remote filter. The other scoop is a cold airbox.
Mad dog
I agree with the above, an oil temp gauge is boring on a stock, street driven engine. The only time I really look at mine is when I adjust the carbs. They seem to be a lot more repeatable / better running if set when the oil is hot. Another check is when the oil pressure drops at idle or about 20 minutes after the water temp is hot. Thats when the oil is hot.
Roy
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
angelfj1 TR2/3/3A Restoring Smiths heaters as fitted to a 1959 Triumph TR-3A Triumph 4
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
T TR2/3/3A Smiths Heater Checkout Triumph 7
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
J Help with Smiths heater. Other British Cars 4
W 100-4 Smiths heater clips Austin Healey 11
G help id this smiths speedo Other Cars 2
K Smiths Electric Temperature Gauge Triumph 7
Tinkerman Jaeger and Smiths Speedometers Triumph 5
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
RJS Smiths PCV Valve Differences? Triumph 2
M Smiths Fuel Tank Sending Unit Austin Healey 3
R smiths guage problem- need advice Austin Healey 4
M Smiths fuel tank sending unit Triumph 1
C Smiths or Lucas Gauge? Triumph 8
58Custom New! Schematic for Smiths RVI tachometer Spridgets 9
Tinkerman Smiths Heater Lables Triumph 11
angelfj1 New WIKI regarding Smiths Heaters Triumph 0
angelfj1 Link to Smiths Heater Article Now Fixed Triumph 0
angelfj1 How To Restore a Smiths Heater Restoration & Tools 8
angelfj1 Smiths Heater - Completely Restored Triumph 3
angelfj1 Weekend Project- Smiths Heater Restoration Triumph 13
amcboy A little about Smiths gauges... Triumph 31
angelfj1 Smiths heater Parts Triumph 8
tosoutherncars NOS Smiths gauges: Bugeye? Spridgets 4
TR674 Smiths Speedo Triumph 9
B Smiths Dual Guage Repair Spridgets 13
wkilleffer MGB Question about the Smiths temp. gauge- 74 MGB MG 19
coldplugs Be thankful [Re Lucas, Smiths, SU, et al Other British Cars 10
dklawson Needed - 4" Chrome Smiths Bezel Triumph 4
A Brighter Smiths Instrument Bulbs --- Any ideas? Austin Healey 25
S Which Smiths heater in '65 AC Cobra? Other British Cars 5
T T-Series smiths or arnolt heater installation in an MGTD MG 1
Kira Smiths Clocks Pre 1950 Other British Cars 6
G Tacho Smiths RVI2401/00EN needed MG 0
G SMITHS SPEEDOMETERS MG 2
J Smiths Tachometer MG 8
KVH General Tech I’m Guzzling Oil One Year After Rebuild—Blowby? Triumph 8
T Wanted MGB Coil Over Front Suspension MG Classifieds 0
T TR2/3/3A Changing oil filter Triumph 3
D 1953 Riley 2.5L Help, Oil Filter Location Other British Cars 2
C TR4/4A Oil pan removal and replacement Triumph 27
