Silicone Gaskets
Gliderman8
Has anyone used one of these Silicone Gaskets?
I have seen others costing a lot more so I'm curious if any of you have had success with this one or it's better to spend the $ on the one costing more?
poolboy
For me it was the best choice. I had one on my 74 and it never leaked.
The 73 had one of those fancy black jobs that cost a lot and I couldn't stop it from leaking a bit.
I replaced it with the red silicone one and no leaks.
The red one is thicker and more easily compressed and at least in my valve covers seals better.
I might add that the cork one on the 74 did not leak but it was getting hard and after removing the valve cover a few times for this and that, I felt it was nearing the end of it's effectiveness..
tomshobby
I have had the higher priced black one for more than 4 years. Having driven Triumphs about 150,000 miles with cork gaskets and now about 20,000 miles with silicon I much prefer the silicon gasket. But I am not 100% happy with the black one. I do not care for the way it sticks out from under the cover and have had to repair a leak twice. Mine is becoming a bit tattered and I have been considering trying one of these red ones before or instead of the black one.
M_Pied_Lourd
Hi Elliot,
I have the one in your link on my 6 and love it. Will never go back to a cork gasket. I have one for my 3A as well.
Cheers,
M. Pied Lourd
Gliderman8
Gliderman8
Thanks everyone. I couldn't ask for a more positive response. It sounds like those of you who have one of these gaskets are happy with the product.
I just ordered one so if it doesn't work out, you guys are in deep trouble :hammer: :jester:
Brosky
I've had no leaks with my silicone gasket from Wagner and I don't think that it sticks out much at all. It is higher than a compressed cork, but it fits under the lip of the cover quite well, IMHO.
Silicone V/C Gasket Installation
tomshobby
A theory of what happened with mine. It twice developed a split in the gasket between the cover surface and the head sealing surface. Both times the split was about 6" long. To be fair, I have had the cover off many times and when the engine was warm I did let it cool for several hours before replacing it. I also cleaned the mating surface so it was completely dry. Looking back it might have happened because the gasket, while being tightened, could not slip to remove stress like it might have if there would have been an oil film.
I repaired it both times with silicone caulk. This last time it has held for over a year.
TR3driver
Great Pumpkin - R.I.P
Just a thought, you might want to discuss that with Justin. If it's as simple as leaving a film of oil on the surfaces, I'm sure he would want to add that to the instructions.
And who knows, you might just get a new gasket out of the deal.
tr6nitjulius
Wagner's silicone gasket for nearly 4 yrs on my TR6, absolutely no leaks and fits well even with off/on yearly to tighten valves, oil film on surface before reinstall is a do. Won as raffle prize was leary about putting it on had it a couple years prior, proved itself to be worthy product. IMHO
TR3TR6
Have that same gasket on my TR6 and also have one on my TR3A. Love them, no leaks, would highly recommend.
ichthos
I have used one on my Bugeye and TR6. I will never go back to cork. I bought mine off of Ebay. I think with postage the TR6 was 15$, and the Bugeye was $12.
Brosky
Good point Randall. Tom you should let Justin know about this.
My gasket was sort of slippery to the touch when I installed it, so I didn't do anything to the gasket surface but I did wipe it down with solvent(between the head and gasket) to be sure it was clean.
tomshobby
Paul, I have a feeling that might be the difference. I wiped the gasket and head surfaces with solvent and they were both very dry.
BTW - I am not considering the red gasket because I am unhappy with the black gasket. To the contrary, I have been happy with it. Just want to try one and compare.
Brosky
Tom,
I did not state my procedure clearly in my post, so let me try again.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]My gasket was sort of slippery to the touch when I installed it, so I didn't do anything to the gasket surface but I did wipe it down with solvent(between the head and gasket) to be sure it was clean.[/QUOTE]
My gasket was sort of slippery to the touch when I installed it, so I didn't do anything to the gasket surface <span style="color: #FF0000">ITSELF</span>. But I did wipe down <span style="color: #FF0000">(with solvent) the gasket sealing surface between the head and gasket</span> to be sure it was clean.
tomshobby
Paul,
Justin did not seem to think it made any difference if it is dry or has some oil on it. He felt it was a flaw in my gasket. He said he had it happen to 2 TR4 gaskets in the past. So although it is very rare it is not unheard of.
I had not considered that possibility and just assumed it was something I might have done.
Brosky
Tom,
I'm glad to see that he stands behind his product. That's a good business man.
BobbyD General MG Gasket Innovations - Silicone Gaskets MG 2
BobbyD Gasket Innovations - Silicone Gaskets Austin Healey 1
BobbyD General TR Gasket Innovatons - Silicone Gaskets Triumph 8
bighealeysource silicone valve cover gaskets Austin Healey 2
M Silicone Rubber Gaskets? MG 1
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
steveg Silicone brake fluid conversion - existing system Austin Healey 41
K TR4/4A The "silicone type" valve cover gasket? Triumph 3
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
mgedit TR2/3/3A Justin Wagner Silicone Valve Cover Gasket Triumph 2
Gliderman8 TR6 Silicone valve cover gasket Triumph 4
Healey Nut Silicone or regular Austin Healey 8
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
B Silicone brake fluid Triumph 15
CJD TR2/3/3A TR3 Brakelight Switch and Silicone Fluid Triumph 17
BlueMax Silicone hoses kits down flow radiator Spridgets Spridgets 1
bighealeysource switching out brake fluid from silicone to Castrol Austin Healey 4
R silicone brake fluid Rover / Land Rover 5
bighealeysource silicone brake fluid question Austin Healey 3
L Use of silicone brake fluid Triumph 16
HAN8L1965 Brake Fluid- Silicone? Spridgets 7
theleisure Silicone or Synthetic, How to Tell Spridgets 5
angelfj1 TR5/TR250 TR250 now has Silicone Brakes but no Clutch! HELP! Triumph 42
Brosky Wagner's Silicone Valve Cover Gasket Triumph 8
angelfj1 Silicone Brake Fluid Warning??? Restoration & Tools 3
angelfj1 Silicone Brake Fluid Warning??? Triumph 26
Brosky Tomorrow, Justin's Silicone V/C gasket Triumph 12
hilsideser to silicone or not to silicone, Triumph 11
2wrench Rear oil seal...silicone or not? Triumph 30
hilsideser Foamy silicone fluid in master cylinder Triumph 22
B Changing to Silicone Brake Fluid Spridgets 18
2wrench Re: Fancy green silicone radiator hoses Triumph 10
roofman TR6 TR6 silicone valve cover gasket Triumph 9
roofman TR6 TR6 silicone valve cover gasket Triumph 2
Brosky New Silicone Valve Cover gasket arrived Triumph 26
BritCarFan Silicone brake and clutch fluid British Motor Corp 7
Don Elliott Removing Silicone Fluid before Painting Triumph 7
C Silicone on wire wheels? Triumph 16
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
RobT Silicone Brake Fluid & Swelling Seals Triumph 6
sultanoswing Question about silicone sealers MG 5
6 silicone brake fluid Austin Healey 24
P Silicone Brake Fluid Restoration & Tools 20
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
R TR2/3/3A Steering Box Gaskets Triumph 4
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
