TR4/4A Running the motor witout the gearbox installed?
karls59tr
Bronze
I think this has been asked before but not sure. Motor in the car...If the back of the motor is supported are there any issues with running the motor?
Should be OK, as long as you deal with exhaust, oil pressure and all that. I've even run them just sitting in the floor.
Make sure it's secure, though. It may jump around some when it first fires off, might knock over a simple jack or whatever.
OK. I'll make sure the motor is secured solidly. The reason I'm doing this is so a potential buyer can hear the motor run. I'm pretty sure I have the wrong clutch pressure plate installed and I don't want to buy a new clutch kit as I'm selling the car. Leave that for the new owner. I'll pull the gearbox to stop the clanging...see my other post.
IMHO....problematical.....spend the money and fix the gearbox/clutch...you should get a better sale price in excess of your fix costs.
TimK running wiper motor on the bench Austin Healey 4
G TR2/3/3A SU carburetor running rich Triumph 9
Todd78d Normal Bugeye Running Temperature Austin Healey 1
K TR2/3/3A The TR3 is up and running again.... Triumph 7
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
TR3sharon TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
D Rough running BT7 3 carb HELP Austin Healey 13
M TR5/TR250 problem getting engine running Triumph 15
