    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Rubber bumper B - Best way to lower ride height
boxofparts
I have seen lowered spindles, shorter springs, use a pre 74 cross member... Has anybody just cut off the raised pads on the existing rubber bumper cross member. I have a nice rust free crossmember and hate to get an old one and have to clean it all up and such and also worry about a new rack.
With the prerequisite of not wanting an earlier crossmember, I'd go with lowered springs (not cut stock ones), and a proper front end alignment... But I have to ask - why do you want it any lower? Mine is stock hight for a '77 model, and drags over speed bumps and sometimes when driving on potholed roads. I guess I can understand if it's a 1975-1976 model that doesn't have swaybars... But then I'd just want swaybars. My 77 can corner with the best of them... even if it sits a whole inch or so higher.
If you cut off the raised pads, you basically have a chrome beam...then, your late steering rack won't work & you'll have to change it!
The proper way is to use an early cross member up front. But if you’re worried about it looking old you can always clean it up & paint it before swapping it out. Otherwise you can just go with the lowering springs. In the rear you have two options and for a street car either are fine – a lowering kit (blocks) or lowering leaf springs.
Me? I went with springs up front and some new leafs with lowering blocks in the rear to give my B a ~2” drop up front & ~1.5” in the rear.
I also added some Polyurethane bushings all around & some up rated brakes components (pads, slotted/X-drilled roters & SS brake lines) and a set of sticky 195/60R14s. Couple those modifications with the front & rear swaybars of the later Bs - should make an otherwise well maintained rubber bumper B handle as good if not better than most any chrome bumper B with the same modifications.
Not for everyone but I like it. My only regret is in parking lots. I always make the folks behind me upset when I have to creep over those “monstrous” speed bumps. /ubbthreads/images/graemlins/eek.gif
Re: Rubber bumper B - Best way to lower ride heigh
Whenever I approach one of those mountains of pavement they ironically call "speed bumps" the people behind me only see my reverse lights coming on! I like my exhaust just how it is--attached to my car.
Durn, that's a fine looking set of wheels Bret. Go over the speed bumps at an angle if possible.
C MGB Rubber Bumper cover removal MG 5
Kleykamp Rubber bumper Midget value? Spridgets 5
JPSmit Rubber Bumper MGB Spotted 0
JPSmit Red Rubber Bumper Midget Spotted 0
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
JPSmit Rubber bumper Midget Spotted 4
B Rubber Bumper Conversion Spridgets 6
Boggsy64 MGB Rubber bumper hides ills MG 5
Simmo MGB Rubber Bumper MGB I have questions MG 4
D Rubber Bumper King MG 6
Trevor Jessie Putting a 1275 in a rubber Bumper car Spridgets 17
SilentUnicorn Rubber Bumper marker lights MG 9
A TR2/3/3A TR-3A hood spring [chrome] rubber bumper Triumph 3
Mickey Richaud BRG Rubber Bumper B Spotted 0
M Rubber Bumper MG "B" Spridgets 26
B MGB Wanted, Rubber bumper MGB rear springs MG 0
B Fixing crack in rubber bumper MG 1
5 MGB Lowering a rubber bumper MGB MG 9
c5racer B Front Air Dam on a Rubber Bumper Midget Spridgets 3
H Post-War Other Herald white rubber bumper restoration Triumph 2
bighly 76 Rubber Bumper Midget Spridgets 3
dklawson MGB MGB - Chrome vs Rubber Bumper [funct. differences] MG 6
J rubber bumper referb Restoration & Tools 14
D Rubber Bumper Sebring Conversion MG 33
tosoutherncars Question - Rubber Bumper turn signal Spridgets 7
Jayrz Rubber Bumper MGB GT Spridgets 2
Jayrz MGB-GT Rubber Bumper MGB GT MG 5
Lin Bumper bar rubber seals to shroud Austin Healey 3
T To the rubber bumper crowd... Spridgets 6
swift6 Rubber bumper question... MG 2
U Rubber bumper replacement. Spridgets 2
Gearhead Rubber bumper to Chrome bumper Spridget Spridgets 2
T Rubber Bumper to Chrome Bumper Conversion MG 28
Baz Rubber bumper 73? Spridgets 14
vping Rubber Bumper B's MG 20
Guinn removing rear rubber bumper MG 6
G Rubber bumper - how to clean, shine, & protect? Spridgets 2
C Fuel Pump in Rubber Bumper Spridgets 17
RTR52nd Rubber Bumper Issue MG 1
rick_ingram MGB NOS Front Rubber Bumper - MGB MG 0
KLUTZ How do I take off rubber off rubber bumper MG 8
PAUL161 Rubber Bumper repair question MG 6
KLUTZ Rear Rubber Rusty Bumper MG 11
KLUTZ TR6 Rubber Bumper TR6 ? Triumph 7
TNMGB Rubber bumper renewal?? MG 9
W Rubber Bumper mounting hole? MG 12
Nunyas The joys of a Rubber Bumper B... MG 25
R front rubber bumper replacement Spridgets 7
B Painting the bumpers on a rubber bumper car MG 8
