Corniche wouldn't idle, compression in the A4 hole (starboard bank, rear cylinder) varied wildly. Sometimes on first stroke it'd go to 120 then fall off, sometimes nothing. always leaked down quickly. Yesterday the rocker cover came off, the exhaust valve is apparently a bit out of adjustment...
Not sure if it has a collapsed lifter (a notorious problem) a bent rod, maybe both. The exploration continues.
EDIT: My bad. That's the intake valve for the cylinder.
