MGB Results of renewing front suspension
Platinum
Though it's been a while since it was done, I've begun to drive the MGB more frequently. The front suspension got new lower A-arms, replaced all bushings with polyurethane ones, new kingpins and bushings, added an MGB-GT sway bar and replaced the steering rack with a "good used" one. Got the sway bar and rack from Tony B. a few years ago.
The improvement is impressive. Body roll has been reduced dramatically. A set of Kumho tires were fitted recently and can't (or haven't yet) had them break loose.
Will next send a set of dampers to Peter for renewal.
The Weber 40 DCOE was a concern, the chokes I first put in were 34's, they turned out to be too big: On 'spirited' application of the loud pedal it would bog down, indicating too much air/not enough fuel. All I had lyin' about was a set of 30's so this AM they got put in. All smoothed out now, but it lost a bit of "oomph" at the higher rev range (Crane cam, too) where with the 34's it came alive at around 3600. I'll dig out a pair of 32's and swap those into it just to see if there's an "in between" in performance.
Amazing what a fresh suspension can do, isn't it?
That sounds really nice.
I've realized that I've never driven a LBC with rebuilt suspension, certainly never owned one. I've never seemed to get to that point. My MGB is tired though not horrible, and the Morris drives like a teeny tiny Buick...
So the next project is a complete rework on the Morris suspension, as it runs well but rides like a wee bitty parade float. Then once the MGB engine is redone I'll tackle that one.
Remembr when I said I only wanted one car? Somedays I remember too...
I falls under th' same tenet as hand grenades, Drew: "One's too many, a thousand ain't enuff".
Truer words, Doc, truer words...
Wish I had a sway bar on mine, but it never had one from day one.
you will sort the Weber....I would give it a rebuild then go from there, if it has been sitting?
Sat too long. Just got the gasket "kit" and new float needle n' seat, along with 32MM venturi chokes, on Thursday. Had to ring up Pierce Manifold for 'em. Hunted thru all my Weber parts and spares with no joy. Amazed me I didn't have a set here. And all my "rebuild kits" have sat around so long they've been shrunken to the point they no longer fit correctly.
This car never had one before, either. The W.A.G. I took was that the GT bar, being the bigger of the two, along with the new bushes and bits would nail it down pretty well.
It worked beyond expectation!
Guess I will need to fit one some day?
Mike is a top man to deal with. He always have just what is needed in stock.
let us know how you get on with the Weber.
kodpkd Compression Test Results Austin Healey 1
Hamish Racing 2022 Sprint and hillclimb championship results uk TR Register Racing 6
Hamish Racing General TR TR Register sprint hill climb championship results (Uk) Triumph 3
AUSMHLY Compression test results Austin Healey 17
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
steveg Definitive results of tests on factors influencing cooling Austin Healey 46
sd80mac7204 Spitfire Road trip to help a friend last weekend with surprising results Triumph 4
M Compression test results Austin Healey 11
R General TR Poly bushings long term results Triumph 4
me61ic Compression results - Worth Rebuiding? Austin Healey 13
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
M New memeber happy with results Triumph 6
G 3.55 Gear results Spridgets 13
pkmh Compression Test Results for BJ8 Austin Healey 14
HEALEYJAG Pebble Beach: auction results 100 Le Mans Austin Healey 4
Rut PCV installation results Spridgets 40
bighealeysource Scottsdale Auction results Austin Healey 4
Number_6 TR2/3/3A Auction results for TR3's Triumph 16
DNK Your results may vary... Triumph 9
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
Brosky Dyno Day today & results with comparison Triumph 16
dklawson Spitfire 1300 Spitfire Compression & Leak Down Results Triumph 15
M $500.00 Midget results Spridgets 23
M Poor Dupli-Color engine enamel paint results Triumph 13
T Fuel pump rebuild kits - good results? Triumph 5
B Lifter/ Rockwell testing results MG 14
BOBBYR Amazing results !!!!!!!! Austin Healey 12
wkilleffer Curious about compression check results MG 5
Hangtown Healey Conclave Gymkhana results Austin Healey 4
zimmy yesterdays drive test results Spridgets 0
rick_ingram HS6 Carb Rebuild Results MG 9
Brosky Not so good results with hoses on Friday Triumph 3
toysrrus Memberships: What was the results? Triumph 0
Dadandson My First Show Results Spridgets 17
Z TR6 TR6 Dyno results Triumph 15
7 New fan shroud - great results Triumph 1
HEALEYJAG Amelia Island Auction 100M Results Austin Healey 22
wkilleffer MGB Worrisome compression test results on my MGB 18GK MG 69
Creatrixx Compression test results British Motor Corp 6
S SCCA results from Vineland and Mid-America Racing 0
apbos Barrett-Jackson Auction Results Triumph 18
J Three questions - no search results Spridgets 38
vping Results of Low Dashpot oil MG 11
rick_ingram Results - Grand Lake Tour MK XIV Endurance Run MG 1
jaybird MG2006 results and a few pics MG 1
mgbmedic Single Zenith Carb- Results MG 1
drooartz Results of first generator tests Spridgets 11
SCguy TR6 TR6 Alignment Results *DELETED* Triumph 19
R6MGS Garage paint job results MG 17
