TR2/3/3A Rear Shock and link remove and replace
jfarris
1956 TR3 with a Girling rear axle
I removed both rear shocks and links today in preparation to have the shocks rebuilt and install new links. The driver's side came out pretty easy because the bottom end of the link was pretty much shot and very flexible in all directions. The link also separated from the shock arm with very little persuasion. The pax side was a different story. I could not get the bottom of the link out of the plate bracket on the bottom of the spring. I had to cut the link midway to get the shock out, then cut the bolt on the bottom of the link to get it out of the plate bracket. To top it off, the top bolt on the link is stuck in the shock lever. I think it will have to travel to Worldwide Auto Parts and they can press it out.
So, my issue is that if the links that are even in so so shape are so hard to get out, how am I going to get a new one into the plate on the bottom of the spring?
Do you have to loosen or remove the u-bolts on the spring to install new shop links? Of course, I'll use anti-seize on the top bolts that attach the link to the shock arm.
Thanks in advance!
Rear shocks are a pain; seems I remember loosening up the U bolts with a floor jack on the leaf or something. Do you know the vibration trick to get the shock off the tapered link? I hold them in midair then smack the shock tapered hole on the side with about a 3 pound hammer and if done correct with the right vibration the link kinda magically falls away to the ground, really. I forget who showed me. I believe someone told me and out of frustration I tried it, and it worked.
steve
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
G BJ-7 Rear Shock Link Austin Healey 2
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
M TR2/3/3A TR3 rear shock link question Triumph 4
JohnnyMead TR2/3/3A Tr3 Rear Shock Link Triumph 4
J Rear Axle Shock Link Help Austin Healey 6
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
H Rear Shock Removal Austin Healey 5
S TR2/3/3A rear shock arms and links Triumph 4
John Turney Left Rear Shock Mount Austin Healey 5
T TR2/3/3A How important are matching rear shock links? Triumph 9
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
S TR2/3/3A rear shock links Triumph 2
mt10flyer TR2/3/3A Rear shock mounting plate Triumph 28
D TR6 Rear Shock Refurb Options 76TR6 Triumph 15
F Rear shock conversion and correct SPAX? Triumph 1
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
regularman Anyone else do their own rear shock conversion? Spridgets 15
C TR2/3/3A Rebuild of rear shock for 58Tr3a Triumph 6
S TR6 tr6 rear shock part number ??? Triumph 5
J rear shock picture; Surely this can't be right? Spridgets 8
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Reh Spitfire GT6 rear shock to spit mount Triumph 3
KVH Rear Lever Shock Help Triumph 6
M rear lever shock? Triumph 21
D Rear Shock Absorber Links Austin Healey 7
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
bigbadbluetr6 TR6 TR-6 rear tube shock conversion question Triumph 20
Z Early BN1 Rear Shock Bolt Dimensions Austin Healey 10
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
K TR4/4A TR4A rear shock conversion kit question Triumph 3
6 Need help with BJ8 rear shock position Austin Healey 2
6 BJ8 Rear Shock Installation Austin Healey 1
mountainman TR2/3/3A TR3 Rear Shock Absorber Fluild Triumph 3
tahoe healey rear shock absorber Austin Healey 9
H TR2/3/3A TR3 Rear Shock Removal Triumph 6
angelfj1 TR5/TR250 TR250/6 Telescopic rear shock retrofit Triumph 2
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
hondo402000 rear shock rebuild Triumph 11
S Rear Tube Shock Converstions Triumph 17
T TR6 TR6 Rear lever shock rebuild: Triumph 3
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
R Rear shock replacement for the KYB conversion Triumph 8
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
Dave Richards Rear Shock Bolts Austin Healey 6
S 1979 rear shock conversion kit worth it? Spridgets 10
W Rear Shock Removal Austin Healey 16
