Rear Shock Absorber Links
Daniele
Hi Guys,
I'm reinstalling the rear shock absorber on my 3000 MKI but I have a doubt. Which is the right position of rear shock absorber link? Are they fitted above the shock absorber arm or below? May you post some picture?
Thanks
Daniele
Hi Daniele,
Above.
Hi Greg
my car is a 3000 MKI, are you sure that the rear shock absorber link is fitted in the same way that the BJ8 in the picture?
Have anybody other pictures?
Hello All,
I would like to jump into this question as well. I have seen photos of as many shock links installed above the axle as below. Seen a "bottom line" write-up saying below.
Would anyone care to comment?
Is above or below correct, it all fits either way? I have had it installed both ways now, and while the car isn't driveable yet, surely would like to get it right!
This is my 1960 BN7 original rear shock link. As from the factory.
Well Tim's Picture above will put you straight.--Keoke
58_BN4 said:
... Is above or below correct, it all fits either way? ...
Yes, but the shock throw won't accommodate the 'wrong' way; i.e. the shock arm would 'bottom' (and probably trash the shock, and maybe the mount).
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
mountainman TR2/3/3A TR3 Rear Shock Absorber Fluild Triumph 3
tahoe healey rear shock absorber Austin Healey 9
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
H Rear Shock Removal Austin Healey 5
S TR2/3/3A rear shock arms and links Triumph 4
John Turney Left Rear Shock Mount Austin Healey 5
G BJ-7 Rear Shock Link Austin Healey 2
T TR2/3/3A How important are matching rear shock links? Triumph 9
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
S TR2/3/3A rear shock links Triumph 2
mt10flyer TR2/3/3A Rear shock mounting plate Triumph 28
D TR6 Rear Shock Refurb Options 76TR6 Triumph 15
F Rear shock conversion and correct SPAX? Triumph 1
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
regularman Anyone else do their own rear shock conversion? Spridgets 15
C TR2/3/3A Rebuild of rear shock for 58Tr3a Triumph 6
S TR6 tr6 rear shock part number ??? Triumph 5
J rear shock picture; Surely this can't be right? Spridgets 8
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Reh Spitfire GT6 rear shock to spit mount Triumph 3
KVH Rear Lever Shock Help Triumph 6
M rear lever shock? Triumph 21
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
bigbadbluetr6 TR6 TR-6 rear tube shock conversion question Triumph 20
M TR2/3/3A TR3 rear shock link question Triumph 4
Z Early BN1 Rear Shock Bolt Dimensions Austin Healey 10
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
K TR4/4A TR4A rear shock conversion kit question Triumph 3
6 Need help with BJ8 rear shock position Austin Healey 2
6 BJ8 Rear Shock Installation Austin Healey 1
JohnnyMead TR2/3/3A Tr3 Rear Shock Link Triumph 4
J Rear Axle Shock Link Help Austin Healey 6
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
H TR2/3/3A TR3 Rear Shock Removal Triumph 6
angelfj1 TR5/TR250 TR250/6 Telescopic rear shock retrofit Triumph 2
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
hondo402000 rear shock rebuild Triumph 11
S Rear Tube Shock Converstions Triumph 17
T TR6 TR6 Rear lever shock rebuild: Triumph 3
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
R Rear shock replacement for the KYB conversion Triumph 8
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
Dave Richards Rear Shock Bolts Austin Healey 6
S 1979 rear shock conversion kit worth it? Spridgets 10
W Rear Shock Removal Austin Healey 16
