Re-keying locks
UmmYeahOk
Ok, my GT6 didnt come with any keys, and I was told that none of the locks were going to match anyway, so I bought a new set from Spitbits where one key fits all. The doors are easy, as they replace the old ones. However the ignition and hatch lock cylinders much be removed. I cant figure out how to remove the old ones in order to install the new ones. Anyone have any ideas?
get an icepick. There is a hole in the side of the ignition lock. If you push the ice pick in there, you will feel a button that once depressed, will let the whole ignition lock come out the front. Replacement is reverse.
The trunk is a little harder, while I am not sure on the GT, there should be chiseled metal holding the lock from the shaft. Once the corners are filed down, you can start removing the lock mechanism.
Now, I know that this explaination is not sufficient, but it is hard to describe how to do it. It may be easier to send the locks to Pete Groh who will re-key them for you.
Jerry
On the earlier ignition switches, you have to turn it to the 'on' position first, and then insert a pin punch or similar through a hole in the body to depress a pin inside (similar to the way the dash knobs work). Then you pull the cylinder out, using the key as a handle.
With no key available (and the switch presumably 'off'), you will need to 'pick' the lock, which is actually pretty easy. You can Google for details (and videos), but basically you apply some gentle turning force while using a probe to lift each tumbler into the 'unlocked' position. The only real trick is applying (and holding) just enough force that you can still move the tumblers, but they won't move back to their 'locked' position.
But I have no idea if any of this would apply to your GT6 or not.
Turns out that was it. My husband bought some picking tools, and man they shipped out fast!!! Also it helps that hes been doing the exact same thing for hours playing the new Fallout game (PS3)
JPSmit Tonight's new skill - re-keying locks. [Vauxhall] Restoration & Tools 1
F For Sale Rover V8 blocks for sale Other British Classifieds 1
LAW75 BJ8 Door Locks Austin Healey 2
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
S TR2/3/3A the door locks Triumph 3
Gearhead_Garage Goldilocks Brakes Austin Healey 14
C HD6 Carburetor Spacer Blocks Austin Healey 4
PAUL161 General MG Posi Locks, Great Connectors MG 2
5 TR2/3/3A Wooden blocks Triumph 3
S MGB Tonneau cover - snaps on cover, twist locks on windshield frame MG 7
bighealeysource BJ8 owners- glove box locks available Austin Healey 13
B TR2/3/3A TR3 keys and locks Triumph 9
5 Hardtop wood blocks Austin Healey 3
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
C TR2/3/3A 1957 TR3 Garage/ barn find> On blocks 48 years Triumph 42
R Jaguar XJ6 Door Locks Jaguar 8
Atomic8 TR4/4A TR4 Locks Triumph 3
T locks and keys Spridgets 2
M MGB Early MGB door locks MG 7
B Sanding blocks Restoration & Tools 2
QuickSilver Looking for wheel locks MG 11
deadair TR2/3/3A For those who's TR3s are up on blocks Triumph 14
M Adjustment of XJ6 Door Locks with Keikert Solenoid Jaguar 5
G Power door locks! Spridgets 23
Brosky Sealing blocks are available again Triumph 5
BOBBYR Sleeved blocks Austin Healey 11
vping Door locks - How do they come off? MG 6
Lin 2" spacer blocks for front suspension Austin Healey 6
longbridgehealey gearshift locks up in neutral Spridgets 18
Mg_Bizzle Lowering blocks and front sus [newbie fitting q's] MG 20
J TR6 how do you remove the door key locks on a tr6? Triumph 2
frankenstang57 Spitfire Spitfire key/locks? Triumph 1
jlaird Clocks, here's the deal Spridgets 14
gsalt57tr3 power locks Triumph 6
SHG Clocks and Rally Timers Austin Healey 16
Darwin Up on blocks Triumph 2
G She's up on blocks....again Triumph 3
R6MGS stubborn door locks MG 5
T Cracks in Alpine blocks Sunbeam (Rootes) 3
Webb Sledge ARG! Stupid Locks... Triumph 12
Webb Sledge Door Locks Triumph 5
Kira Smiths Clocks Pre 1950 Other British Cars 6
