Radiator Recore
mylesw
Hello
Took my TR4 radiator down to the radiator shop to get cleaned out. In this process the radiator shop have managed to get a working radiator to leak....anyway, they want $425 for a recore. Apparently the current core is 2 3/4" but the replacement core is 2 5/8". Does this sound right/easonable? Also, gave me the option of some zigzag radiator vs the straight one that is standard. Anyone got any experience with the zigzag radiator? Can you attach an electric fan to these?
Lots of questions, thanks for your help.
Myles
Myles-
How authentic do you want to be? For that money you can go aluminum. Haven't checked the bidding, but there was a nice one on ebay this past week (albeit with the early style header tank) for $399 I think.
Frankly, the price quoted to you sounds high to me, but I don't have a good experience base. I have bought used radiators for less than a quarter of the price and they've been fine though.
Randy
I am not sure how the TR4 radiator differs from the one for the 6 but, Ron Davis makes a beautiful one for a little more than you are talking about.
https://www.rondavisradiators.com/new_products.htm
Also, when you say zigzag radiator, if you mean a double pass cross flow radiator. The guys at Ron Davis told me that they see a 20 degree greater temperature drop (inlet to outlet) with that style as opposed to the standard style.
Re: Radiator Re core
Aloha Myles,
I've had TR3 radiators recored with the standard type core for about $200 - $250 recently, so I think the $400 quote seems high. Usually everything in Hawaii costs more than other places. The shop I use cleans the radiator, re cores it, pressure tests it and repaints the radiator for that price. Repairs to the tanks if required sometimes adds a few dollars.
I've been satisfied with the cooling of the standard radiator. If you were concerned about overheating with the radiator before, you might want to consider the the cross flow (zig zag) core for improved cooling.
If the shop over pressurized the radiator during testing, seem to me they should offer some discount for the re coring.
Me too.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If the shop over pressurized the radiator during testing, seem to me they should offer some discount for the re coring. [/QUOTE]Just chemical cleaning can sometimes cause an old radiator to start leaking; rodding out definitely can. My shop has warned me on several occasions that the core might not survive the cleaning process (and stated they would not charge me if it didn't).
I'm wondering if perhaps "zig-zag" vs "straight" doesn't refer to the fins rather then the tubes. The original radiators had fins that ran horizontally, while modern radiators have fins that zigzag back and forth between the tubes.
Since the problem with my original radiator was that the tubes were no longer in good thermal contact with the fins; I have to think the zigzag design is better (since the fins are soldered/brazed to the tubes).
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I'm wondering if perhaps "zig-zag" vs "straight" doesn't refer to the fins rather then the tubes. The original radiators had fins that ran horizontally, while modern radiators have fins that zigzag back and forth between the tubes.
[/QUOTE]
I think you're right about that Randall.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Since the problem with my original radiator was that the tubes were no longer in good thermal contact with the fins[/QUOTE]
This is a problem area often overlooked. If the fins are not connected to the tubes, they can't conduct heat from the tubes to shed heat.
Thanks for your comments. I'm exploring some other options however the other radiator shop wants to know the height of the core (tank to tank), the depth of the core (which I was told is 2 5/8") and the number of rows of tubes in the core (which should be of the order of 3, 4 or 5). Not having the radiator with me I am not able to do this myself. If someone has this info handy or could measure their radiator for me I would be grateful.
Thanks
Myles
My favorite design is a louvered copper plate and tube design... aluminum doesn't conduct heat as well as copper so I'm firmly in the copper camp.
Here's some info from US Radiator. I've used their radiators in several hot rods and they work very well.
https://www.usradiator.com/options.htm
smaceng BE radiator recore Spridgets 10
BugeyeNJ58 Cost to recore radiator? Can a radiator be identif Spridgets 7
G recore radiator Austin Healey 3
G For Sale TR4A NEW Wizard Cooling Alloy Radiator in Original Box and Packing - Triumph Triumph Classifieds 0
71TR6 For Sale TR3 Radiator with crank hole- refurbished Triumph Classifieds 3
AUSMHLY BN4 Radiator Cap Austin Healey 4
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
K TR2/3/3A Pressure testing the radiator to find a head gasket leak? Triumph 7
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
