RAC68
Hi All,
Radiator Core Replacement:
During a member conversation on improving the cooling of a friend's BJ8 at last nights AHS&T meeting, re-coring of the original radiator was brought up. Many of us have had this done but now finding a facility to upgrade the cooling capacity of an original radiator is becoming more and more difficult. Although my experience and upgrade exposure is to a 4-row Core upgrade, I was informed that there is a Dual Density core replacement that better fits the confines of our original radiator and also increased coolant capacity by close to an additional gallon.
Can anyone provide experience of this dual density core replacement? What cost range can be expected for the replacement?
Sleeve Thermostat Alternatives:
As a proponent of using a Sleeve Thermostat to block the cooling bypass, I was informed that the limited availability of the thermostat has increased the price to a ridiculous level. As an alternative, a Thermostat Bypass Blanking Sleeve (https://mossmotors.com/austin-healey-100-100-6-3000/cooling/sleeve-thermo-bypass-blanking) that will close this passage and eliminate as much as 25% of coolant from passing through the radiator. Since most are will not be using their Healeys during cold mid-winter days and can put up with a slightly longer warmup period, is this blanking sleeve a viable alternative? Can this blanking sleeve be combined with a standard thermostat to maintain effective pressure and flow?
Thanks all,
Ray(64BJ8P1)
Thanks all,
Ray(64BJ8P1)
