powder coat prep work?
JonnyRotten
I sand basted my parts.What else should I do before powder coating.I thought I read I should rinse with acetone?Is there any specific procedure I should do?Also will standard powder coat(up to 400F) work on calipers or do I need high temp?
I have not powder coated automotive parts but used to have industrial parts powder coated. Basically at this point your goal should be to wash the parts to remove any oil or dirt residue... just like you would with spray painting. Hopefully you degreased the parts before sandblasting so you didn't drive the debris into the surface. Regardless, Acetone or any other prep solvent you would normally use prior to spray painting will work.
As for calipers, they do get hot, but 400oF is pretty far up there. The wet boiling point for "new" fluid may be above that, but once the fluid has been in use for a while the boiling point is lower. If you manage to get the brake caliper up over 400oF, you probably have more to worry about than damaged paint.
I use the metal prep Metal Wash that I bought with the powder, from Eastwood. You mix with water and spray on. Always wear gloves - this stuff is a mild acid. Never touch a prepaired surface with your fingers. The oils on you skin will prevent proper adhesion of the powder.
I agree with not every touching parts with bare hands. I wear disposible rubber gloves the entire time I am handling parts during and after sandblasting. I also preheat parts and then let them cool before powdercoating, especially on cast parts. More than once I thought a part was blasted clean only to have oil or greese seep out from somewhere when I heated it up.
I did not have any blasting equipment available to me
so I improvised. I stripped each piece with a paint gel
strip compound and wire brushes. Washed the part in paint
thinner. Next I soaked them 24 hours minimum in a liquid
degreaser. Soap and water final cleaning and then preheat
to dry. A final wash with fast drying acetone and then spray
the powder.
As mentioned, never touch the final cleaned piece with fingers.
Mine might not be quite correct procedure but it worked for me.
I worked with the chemicals in a well ventilated space.
dale(tinster)
I degrease in kerosene for grease removal. Sand blast in a blast cabinet (my parts were very rusty), wash with Metal Wash (Eastwood product, rust inhibitor and degreaser), and then bake at 400 for 30 minutes to dry. I always preheat at 400F before powder coating. There is nothing better than powercoating a hot part. It sticks better and you can remove ground clip and stick gun up close in corners and add powder where it doesn't want to flow otherwise.
The 50 year old parts look like new and are bulletproof.
Pat
Nice pictures, Pat - hope your wife wasn't around when you snuck those springs into the kitchen oven!
Wow, my powder coat oven isn't that clean.
I usually wire parts to be coated to the oven rack and slip the rack into a coating box (old dishwasher box) that has an internal wooden frame to hold the racks. I cut an opening on the top of the box for a flourescent light and clip the ground to the rack. I lined the bottom of the box with 6mil plastic sheet to reclaim powder. The box keeps the excess powder contained. Also, I always wear a 3M particle mask while coating. Remember, if you can smell it, you're inhaling it too.
Then it's just a matter of carefully sliding the rack with coated parts into the pre-heated oven. 400 for 20min. I put an electronic timer in my pocket so I can leave the shop while the powder cures - fumes are toxic, so I've read.
The reason to preheat cast parts is to bake out the moisture so it doesn't foul the coating during curing.
Peter - any chance you can post a photo of the dishwasher set up? Thanks
Sure. I'll snap one for you this afternoon. It IS just a box but I built an internal wooden framework for it.
I bought an almost new digitally-controlled oven on Craigs list for $50 and built some storage cabinets and installed wall-mounted oven. Had to extend 220V to it, though (note, ovens require 22V with neutral and ground, because some circuits are 110V). Many 220V circuits don't have neutral.
Those coil springs were done with Eastwood Argent Silver and satin clear coat. That was my first try with clear coat and they came out beautifully. I'm still a neophyte powder coater but honestly, parts look like they are professionally done.
My wife didn't mind except she was jealous as the oven was cleaner and nicer than the one that came with our house. Given how she can barely walk thru the garage, I think the oven is the least of my worries.
Pat
Very nice Peter
If this will keep powder off my kids snowboards and bikes, my wife will be slightly happier with me (that's an incremental move in the right direction).
Do you have a favored powdercoat supplies suppler? I use Eastwood but am always looking for other options.
Gosh, <span style="font-style: italic">it's good to be an American</span>...
Thanks for posting Peter. I thought you meant you were <span style="text-decoration: underline"><span style="font-style: italic">using</span></span> a dishwasher "box", (i.e. plastic interior).
I think I'll look for a D.O.A. dishwasher, (they're abundant), pull the door, guts and motor. I think I can put the oven and a powder coat spray booth side by side, at a good working height, in my shop.
...<span style="font-style: italic">resourceful</span>, Frank.
In fact, I'll have to look at a few of those cases and see if there are any with a continuous lip, so as to join 2 cases face to face. Could be the basis for a blast cabinet. hmmm...
bighealeysource Good match for RENO red with powder coat color Austin Healey 3
T Powder coat or eurythane [sp?] Triumph 18
J TR2/3/3A TR3 fan powder coat Triumph 3
G Need info on powder coat equipment and books Spridgets 5
svtmikey What type of powder coat system do you use? Restoration & Tools 10
T Can I powder coat this stuff or will it look dumb? Spridgets 10
T Powder coat or paint front spring pads and arms? MG 37
T Powder coat or paint springs? Triumph 7
B powder coat wire wheels?? Triumph 8
T Will stripper work on powder coat? Triumph 16
angelfj1 Powder Coat Setup Triumph 8
paulpo69 To powder coat or not... Austin Healey 7
fmichaels powder coat Latest Spridgets 21
W Powder coat vs Paint Spridgets 24
I Painting wheels -powder coat vs conventional paint Triumph 13
milemarker60 Powder Coat or POR15 Frame? Triumph 11
R Powder coat front suspension Jaguar 2
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
D Powder coating Spridgets 20
Zimmycobra Powder Coating wire wheels? Triumph 10
Magyar Powder Coating Wire Wheels Austin Healey 19
J Wire wheel prep for powder coating? Spridgets 7
M opinions on powder vs. chrome. Triumph 16
Tr4dude TR6 Tr6 rim before and after powder coating. Triumph 16
Tr4dude More parts renewed with Powder!! Triumph 0
R powder coating Austin Healey 7
Twosheds Powder Blue Club Triumph 14
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
Tim Tucker Caswell Hi-Temp Powder Coating Triumph 1
T So let's talk about powder coating Spridgets 17
A Foot powder finds oil leak! Austin Healey 12
jvandyke Powder coating snafu Spridgets 8
T ? on powder coated wishbones b/f reassembling Triumph 9
Tinkerman Powder Coating Wire Wheels? Triumph 7
S Powder Coating Temperature Triumph 17
S Powder Coating Temperatures Restoration & Tools 5
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
Brosky Playing with powder coating [not me...] Triumph 15
Brosky Powder coating process [stateside, not PR] Triumph 47
T Home Cooked Powder Coats Triumph 22
Brosky Powder coated chassis parts are back Triumph 27
Brosky Powder coating begins next week Triumph 2
Bret Manifolds Powder coating vs. Painting? MG 24
kyreb1862 Powder Coating A Windshield Frame MG 7
beaulieu DIY powder coating , how good does it work ? Restoration & Tools 10
C Car Status and Powder Coating a Top Frame... Triumph 12
F Engine Paint...powder coating or just high temp? Triumph 7
Brosky Plug for Bob Greene of Cape Cod Powder Coating Triumph 5
Brosky Intake and exhaust manifold powder coating Triumph 18
