Porsche 911.....anyone know anything?
Steve
Platinum
My brother's new toy, a 1986 air-cooled car, doesn't want to start. He has replaced the battery, but still no joy. No clicks, just silence when he turns the key. I suspect the starter relay........anyone know where it is on one of these?
Bruce Bowker
If I understand it correctly the starter solenoid may also be the relay.
Bruce
"The solenoid is designed to do double duty: it first pulls a lever which causes the starter pinion to slide out on it’s shaft, and then continues on and closes the high current contacts that apply power to the motor."
Steve
Steve
Platinum
Ah, you da man, thanks Bruce!
I have been doing a little research, and apparently the ignition switch may be at fault also. Worth checking into, the symptoms sound remarkably similar.
Bruce Bowker
Nothing more fun than tracing down electrical problems. /ubbthreads/images/graemlins/mad.gif
Bruce
Ich Vonder. Ist die elektriks von Herr Lükas?
Gibt es viel Rauch? (see babelfish)
beaulieu
If you can get the car up on a lift ,
you can cross the wires on the starter (key off) and see if it turns over , if it does
then work your way up to the ignition switch (which sometimes breaks the electrical contacts internally )
Platinum
There's relay box under the front lid on the right side inner fender (FACING the car) behind the carpet...I think the starter relay is there. If not, look in the engine compartment on the left (driver's side) for the covered relay array... but I'm fairly sure those are mainly fuel management only. Is this a CIS or an EFI car? Gettin' old is a terrible thing... RAM is a bit slow these days /ubbthreads/images/graemlins/wink.gif
Steve
Steve
Platinum
"RAM is a bit slow these days "
That's the missus' biggest complaint......
It's an EFI car. I have read something that is pointing to the ignition switch so we're going to explore that possibility too. I'll check out the locations that you gave though. Thanks all!
Platinum
The relay legend is on the underside of the cover and a "quick and dirty" way to check it: swap out another of the relays for the starter one. Then you'll KNOW it ain't the relay.
Platinum
WELL, Steve?!?! What happened? Izzat thing chimin' up yet, or just upscale yard art?
Inquiring minds wanna know.
Steve
Steve
Platinum
It lives! It appears to be the ignition switch, as these are known for getting grungy after years of use, and are affected by extremes of temperature. Well, it was extremely cold when he was trying, and failing, to start the beast, and once the weather took a turn for the mild a few days ago the thing cranked and ran like a Swiss watch.
Spring project will be to remove the ignition switch, clean the contacts, spray with some of that magical electrical stuff, reassemble and keep fingers crossed, which is supposed to work. Except the crossing of the fingers, the jury is still out as to its effectiveness.
I shall have to be the primary technician, as my brother's philosophy of auto repair is to pull out his chequebook, which with a Porsche will rapidly lose its appeal. Who knows, maybe I can make a converted gearhead out of him?
jfarris New Porsche 911 Speedster Spotted 2
jackq Porsche 911 Other Cars 2
Nunyas Singer Porsche 911 Other Cars 6
jackq Porsche 911 Other Cars 15
10musketeer Porsche 911 Fuel tanks Other Cars 20
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
jackq Porsche 911 Other Cars 13
JPSmit Porsche 928 and Camero Z28 Spotted 0
Sherlock Winter Porsche sighting Spotted 1
3798j Porsche 919 Tribute Tour Other Cars 0
P Porsche with 5 headlights Other Cars 5
AngliaGT Porsche 356 Spotted 5
Boink Porsche 993 Other Cars 2
P Porsche 918 Other Cars 2
jackq Porsche 912 Other Cars 4
Nunyas 1955 Porsche 356 video Other Cars 3
AN5Sprite Porsche 356 w/ bonus Chevy Spotted 4
drooartz Parade of 15-20 Porsche Panameras Spotted 0
F Porsche v. Healey guess which one is running? Austin Healey 1
Jim_Gruber BE Sprite vs. Porsche Spridgets 12
dougie Mini vs Porsche British Motor Corp 1
K 1977 Porsche 924 Other Cars 0
Z Chevron B16 Videos at Summit Point. Porsche 907LH Racing 1
aeronca65t slowest Porsche Other Cars 3
V Ultra-rare Porsche 914-6 GT factory racer! Other Cars 2
Bruce Bowker Porsche Other Cars 12
boxofparts TR2/3/3A TR3, MGA,Porsche and MGB video Triumph 9
aeronca65t Porsche Other Cars 2
Baz What's the opinion on Porsche 914's? Other Cars 19
S Healey and Porsche "barn finds" previous posting Austin Healey 14
JPSmit Porsche 924 question Other Cars 11
toysrrus "WANTED" Porsche 356A Speedster 1/18th Die-Cast: Other Cars 4
Bret NASCAR cooling technology in a Porsche!?! Other Cars 16
Nunyas Porsche 914 Other Cars 6
Bret Porsche & wine tasting show & shine. Other Cars 5
T OT - Top Gear beater Porsche challenge Triumph 2
Bret A Porsche is not a Porsche Other Cars 49
sparkydave Porsche question - 356 1600 super Other Cars 21
JoeC Porsche fuel tank cleaning Other Cars 12
Steve New Porsche in the works? Other Cars 8
waltesefalcon Porsche 356 parts needed Other Cars 8
Earl Need some advice on a Porsche?????? Triumph 0
Earl Need some advice on a Porsche?????? Other Cars 19
Sherlock News out of Germany - Porsche/VW Other Cars 7
aeronca65t Tiny Porsche Other Cars 7
G Info on Porsche 944 Other Cars 8
Sherlock Check out this Porsche Other Cars 4
jfarris Singer 911 @ the Barber Historics Spotted 0
PC didn't spot a 911 or a Javelin but did see a station wagon Spotted 1
jackq 911 Other Cars 1
