Pictures from the All British Field Meet
SeaSix
Not sure where to post this, since there are many marques in these photos. Lot's of Lotus', Triumphs, Mini's, Morgans.
https://s224.photobucket.com/albums/dd27/SeaSix/ABFM%202009/?albumview=slideshow
Here are a few photos, and the link to the Photobucket album is below.
Tom, sorry to post a pic of your car without your permission!
Dave (TOC), the black TR6 you saw was probably Tom Sewell, pic below.
And the Photobucket link again:
Deleted member 8987
Wasn't Tom's.
I met him at the social gathering the night before, and he was surprised there was another one in the area.
If I could get the software here to accept my photos, I would download some of the meet.
That early Triumph, I have a front-on shot of it.
Dave
TR3driver
Great Pumpkin - R.I.P
Easiest/best way is to open an account on Photobucket (or any of the similar web sites) and then put IMG links into your post here. Photobucket takes care of resizing and so on; plus that way it doesn't burn up space on Basil's server. Only downside is that if you delete the photos (or lose your account) on Photobucket, they will "go away" on BCF as well.
To get started, go to https://www.photobucket.com/ and click on "join now". It's pretty painless. Then once you've uploaded the photos you want to share, you can either post a link to the album, or those IMG codes I was talking about. To use an IMG code, open a new window for your Photobucket album just let your mouse pointer hover over the photo thumbnail on the PB page, which should cause a menu to pull-down from the photo. Click in the box labeled "IMG Code" and press Ctrl-C.
Now Alt-Tab to your BCF post and press Ctrl-V. You should see something like [IMG.]http.//i258.photobucket.com/albums/hh260/TR3driver/FergusonTEA20tractorskeleton.jpg[/IMG] appear in your post (I've changed it slightly so the string will show instead of the image).
To see the result, click on "Preview Post".
DNK
OK,I've seen these. Where else did you post them?
AngliaGT
Thanks for posting the pictures.
BTW,the Lavender car is an original Elite,
not an Elan.
- Doug
SeaSix
SeaSix
Ok, Don, ya caught me. I posted the link on the 'other' forum as well.
:blush:
Dave, I looked for you, but didn't spot your Jag.
I was surprised I hadn't seen that modded TR4 earlier. There's been some work done on that one. I'm not a big fan of spoilers, but that one fits nicely between the rear wings
Brett
TR4A_IRS
I think that TR4 V8 owner lives in Issaquah. I see the car (usually hear it first!) from time to time and had a chance to talk to the owner once. He has done a lot of nice work to that car, if you like that sort of thing. He fabricated a lot of stuff to get the V8 to fit and to improve chassis stiffness.
Deleted member 8987
I was parked in the Jag section.
The photos up of the XK-120's I was looking at through my windscreen.
I was there from 1000-1500, had to go as legs were going, and I had to drive home.
There were three MK2's, I think, the other two being versions of BRG.
I just got uploaded (with a little help) my Avatar, which is a pix of my MK2 as-delivered 14 months ago.
Looking through on-line photos, my car isn't even in the background of any shots!
Dave
DNK
Got home from Bend on late Fri. and found out I had ballgame tickets. So no trip this year.
As usual it was a warm one.
Brosky
I like that black TR6. Thanks for posting. Nice job.
SeaSix
SeaSix
It looks better in person. Tom Sewell has a nice car. It has the 6 pack Keihin Carbs as well. I've only spoken with him through emails, but he says they run great, no problems after initial install and calibration.
There were many other nice cars there, so I don't want to overlook all of the other participants. Many more TR3's than I expected, many more Morgan's than expected(but they were celebrating 100 years of Morgan at this meet). Very few TR6's though (I think I counted about 8).
Brett
S General TR British Car Show Pictures - Is there Interest in Posting? Triumph 7
BobbyD The British Invasion - 200 Pictures Posted Triumph 8
TR_Jim British Car Festival Pictures Triumph 9
TR_Jim British Car Festival, Palos Hills, IL-Pictures! Triumph 14
budk1953 British Car Graveyard Pictures MG 33
Sherlock British/European Car Show pictures [Calgary] Other British Cars 7
Sherlock Car Show Pictures [non-British, but true vintage] Other Cars 2
Sherlock Pictures from Stowe, Vermont - British Invasion Other British Cars 5
Sherlock Pictures from Calgary European & British Car Show Other British Cars 5
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
Basil Admin Note Posting Pictures on BCF MG Classifieds 0
B Brake Line Pictures Austin Healey 1
LAW75 Engine Pictures Austin Healey 33
Hamish Racing TR2/3/3A Pictures through a corner. Triumph 7
steveg TR6 Hood release pictures needed Triumph 22
A Disc Brake pictures Austin Healey 1
HealeyRick Disoriented Pictures FORUM Navigation Questions 11
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
trrdster2000 Spitfire Added a few pictures to my Photo Album of the Spit6. Triumph 0
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
Jim_Gruber Pictures of Clutch Slave Plumbing with Gerard's Kit Spridgets 4
T Trouble inserting pictures to post FORUM Navigation Questions 2
D looking for pictures / info 62 BT7 Austin Healey 5
T TR2/3/3A Clutch and oil line Pictures requested Triumph 9
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
J pictures of a 3000 on a rotisserie ?? Austin Healey 5
K TR2/3/3A Auxillary dash switch pictures? Triumph 14
M Off Topic TRA National event pictures Triumph 6
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
J TR2/3/3A 1957 rear seat carpet pictures Triumph 7
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
Basil TR2/3/3A Karls59tr pictures Triumph 9
B Rear seat backrest pictures Austin Healey 6
T TR4/4A Anyone have pictures handy of TR4a with TR6 steel rims? Triumph 13
Tinkerman TR2/3/3A Pictures needed Triumph 4
boxofparts TR2/3/3A Pictures of my own Garage Find TR3 Triumph 10
7 unable to upload pictures - Java problem? FORUM Navigation Questions 7
RickB General Tech Need pictures showing how to connect choke on HIF carbs. MG 2
Randy Forbes Randy's Healey pictures links... Austin Healey 7
Basil Posting pictures on BCF Triumph Classifieds 0
Basil Posting pictures on BCF Spridgets Classified 0
Basil Posting pictures on BCF Jaguar Classifieds 0
Basil Posting pictures on BCF Other British Classifieds 0
Basil Posting pictures on BCF Austin Healey Classifieds 4
M TR2/3/3A TR3 progress pictures Triumph 26
T Any pictures of Rx7 E-brake cables? Spridgets 6
