Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals
Jim_Gruber
I had some time this afternoon and I am reassembling my pedal box. There is a little bit of slop in the pedals and I thought about adding a washer in the middle to help stabilize and reduce movement on the pedal shaft. And it does reduce a certain amount of side to side slop. Yes I could drill out the pedals bolt holes by a very slight amount and fit a microfinish bolt. I did this once before on Bugsy I and I'm not certain I drilled the bearing surface squarely. And I even have one of those bolts around here. I'll leave that for another time.
Anyway as it stands now the washed does not move freely and is perhaps a bit crooked. I'm taking it back apart to grind an edge flat on the washer so it can rotate and move as needed. Pedals move freely returning to rest even before I add the return springs. Next steps is adding the pedal stop bolts. IS there a procedure on how the Pedal Stop Bolts are adjusted. ThanksView attachment 48168
As I look at the BMC Shop Manual it calls for a Distance spacer between the pedals. Guessing that means a washer. Anyone know how thick?
Just did this Jim and the washer/distance piece went flying. I tore apart a junk pedal assembly for a replacement and would put it at about 1/8" thick. Maybe 3/16".
Kurt.
Thanks Kurt,
i ground the side of the washer down so it is now D Shaped and put back in place. There was no washer in place previously. Polished up the bearing surface, some grease and assembly works fine. Ran out of time to finish last night but about 15 m to connnect brake lines and finish tidying up yet left to do.
Radiator to install and then to get to get the differential pulled and then out in the driveway for degreasing and pressure washing. Brajes, bushings, wheel bearings, spring rehab and paint. New gas tank going in and then reinstall of dif with new 3.9 pumpkin. Need to order tires for my new wheels and get them mounted and install the front tilt kit. Or that may wait as I want to go drive to enjoy new suspension, disk brakes, new shock and stop fixing and enjoy driving.
Jim,
Get a bronze washer and I used a lock nut to get the space right...made it smooth as budda!
Rut
Pretty smooth now Rut. But easy enough to find a bronze washer and swap. Good progress today with MC install finished. Radiator reinstalled, old gas tank drained, no wonder Bugsy had issues running last Fall, only about 3/4 of a gallon was in there, did see some rust specks in the gas when I drained. Not much but definitely there. Glad I bought the new tank. Bugsy got jackstands repositioned and he is ready for the differential to come out. Tomorrow afternoons task after Church and Brunch. Take care. Happy Easter.
K For Sale TR3 Pedal Box Triumph Classifieds 0
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
K For Sale TR3 pedal box Triumph Classifieds 0
simon1966 Pedal box blanking plate for a RHD Frog Eye Austin Healey 5
Rut Pedal box blanking plate Spridgets 10
AngliaGT Early '74 Midget - MC/Pedal Box Replacing Spridgets 3
M Screws vs bolts for pedal box attachment to body Spridgets 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
Jim_Gruber Need BE Pedal Box Cover Spridgets 15
Tr3aguy TR2/3/3A Pedal box Tr3 Triumph 5
Branson later spridget pedal box install in early spridget Spridgets 21
Rut Bugeye pedal box Spridgets 2
T Pedal box seal question Spridgets 3
J TR6 TR6 Pedal Box Triumph 9
Branson Question re: master cylinder and pedal box Spridgets 11
Thor Brake light, do you have to remove pedal box? Spridgets 2
G Pedal box assemby Spridgets 7
Alan_Myers TR6 with TR6 pedal box and MC in TR4? Triumph 6
Thor Does the coil mount on top of pedal box on 1500? Spridgets 2
fmichaels pedal box bolt Spridgets 10
77_MG_Midget Pedal Box Bolts for '77 1500 Midget Spridgets 6
P Pedal Box Cover Screws MG 6
philman Wedge tr7 pedal box Triumph 3
F Excessive Brake Pedal Travel Austin Healey 3
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 22
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Sopwith_Camel MGB pulsing brake pedal MG 10
CARSINC MKIII Accelerator Pedal Spridgets 0
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
P Pedal Position Adjustment Austin Healey 2
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
T Clutch Pedal Engagement Point Austin Healey 1
K TR2/3/3A The Dead Pedal Triumph 3
petnatcar Dead Pedal Austin Healey 12
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
bighealeysource Soft Brake Pedal Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
DrEntropy MGB Pedal extension MG 6
Jeepster Clutch Pedal Position Austin Healey 4
DrEntropy General Tech Pedal freeplay MG 6
S Receding Brake Pedal Austin Healey 32
C BN1 Clutch Pedal Rattle Austin Healey 2
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
G TR6 Binding Clutch Pedal Triumph 5
K Midget Brake Pedal Question Spridgets 2
D TR2/3/3A clutch/brake pedal question Triumph 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
D Gas Pedal Pad Jaguar 7
P TR6 Clutch pedal click noise Triumph 2
