Overdrive solenoid problem on a BJ8
shorn
Recently I had to replace the overdrive solenoid on my 1964 BJ8. This was an aftermarket solenoid that had been in the car just a couple of years. The solenoid would not engage and actually would blow a fuse (added a fuse to this wiring a few years ago). The new Moss aftermarket solenoid seems to engage properly and the overdrive works. Just wondering if others have had this experience with the aftermarket solenoids. Perhaps I need to do some adjustment to see if it is fully engaging, but I believe that to be the case. Thoughts
shorn
What size fuse did you add-??????
Its worth the time to study the shop manual to adjust the operating lever properly or risk burning out the solenoid if the plunger doesn't fully pull up on engagement.
Hi Shorn,
I have experienced 2 issues in the past that have caused slow or no O/D activation. The first was when the button under the plunger flattened over time to cause the solenoid plunger to extend very near or past the coil's effective pull range and cause the O/D to "sometimes" activate. Since the old rubber button was still in place and under the plunger during the initial investigation, I overlooked its condition until totally removing the solenoid in preparation for solenoid replacement.
My second issue was as a result of using Red Line MTL fluid in the O/D. This is a very good manual transmission and overdrive synthetic fluid but also tends to leak through any possible orifice. Although I did replace the "O" ring that seals the O/D activation shaft passing through the O/D, it was obviously not sufficient to constrain the MTL fluid and it filled the solenoid housing (the BJ8 solenoid housing is a closed compartments) sufficiently to lock up the plunger. As it turned out, I may have overfilled the unit and the simple fix was to reduce the MTL fluid level within the transmission/overdrive to just below the shaft "O" seal and, as Brinkerhoff suggested, readjusted. All has worked perfectly for the past 10 years.
One last point. I had installed a 10 amp in-line fuse at that time to protect the car's original solenoid and have had no issues.
All the best,
Ray (64BJ8P1)
A TR4/4A TR4 Overdrive Solenoid Triumph 19
T TR2/3/3A overdrive solenoid Triumph 3
R TR2/3/3A Overdrive Solenoid Triumph 6
B Overdrive solenoid Austin Healey 12
S TR2/3/3A Overdrive Solenoid Issues Triumph 11
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
nevets Access to overdrive solenoid and switch Austin Healey 5
vickxxx TR2/3/3A Overdrive solenoid sticking Triumph 6
S TR4/4A overdrive solenoid rubber boot Triumph 8
M AHBJ8 '67 overdrive solenoid Austin Healey 8
2wrench New Solenoid Installed on J Overdrive and now no juice to the Solenoid. Triumph 3
H overdrive solenoid question Austin Healey 4
bighealeysource Help -think I've got a bad overdrive solenoid ? Austin Healey 8
bighealeysource Overdrive solenoid on BN6 Austin Healey 2
thechileman TR4/4A Overdrive Solenoid issue TR4 Triumph 8
B What's the BUZZ from the overdrive solenoid Austin Healey 3
6 overdrive solenoid Triumph 5
Ed_K Overdrive solenoid rubber piece on a BJ8 ? Austin Healey 2
J Overdrive solenoid--How do I diagnose weakness? Austin Healey 8
kch Overdrive solenoid - fuse question Austin Healey 8
Y MGB Overdrive help needed... MG 2
S Gearbox/Overdrive Lubricant Recommendations Austin Healey 9
71TR6 TR2/3/3A Switches on the top of an Overdrive Triumph 2
RichB4493 Wanted TR3a overdrive dashboard switch Triumph Classifieds 4
B BN1 Overdrive Austin Healey 5
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
