• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
Organizing threads into book?
JimLaney
Basil,
For some time now I have been gathering books on restoration of vintage vehicles mostly to learn exactly how to work on my two MKIII Sprites. I get great help from members of the Spridigits forum if I ask the right question or make the right search. It seems to me that it would be possible to create a detailed "how to" book or wiki from these pieces of wisdom organized by tasks or subsystems. Is there a way to do this? Is any one other than I interested it such a project....or is that bad form?
Administrator
Boss
I would be an interesting undertaking but I suspect would required a good amount of work on someone's part.
JPSmit
Not necessarily - already you have a "show printable Version" as one of the thread tools - would only take a cut and paste to throw it in Word and format it.
JimLaney
JimLaney
Looks like it still might take a good bit of time but cutting and pasting is far better than re-typing. Working from the premise that you put things in sections/piles then edit a few times... that might work but it is still a lot of hours staring at the screen....uggggh!
Administrator
Boss
There are over 186 thousand posts. The time consuming part would be reading through all of them and deciding which to clip out and past and also how to organize. Not as simple as just cutting and pasting - some thought has to go into it.
NutmegCT
I tried JP's suggestion of "show printable version" - and discovered that photos aren't included. So downloading and fitting the photos would add even more time to the process.
eek
Hmmm - now that JP is all rested up after his seven week vacation, I nominate JP for the job!
JPSmit
eek
Happy to!
After the Vauxhall is done
and the Multipla
And the basement
and the breezeway
and the back porch
and the front porch
and I have joined the procrastinators club
and
and
and
:grin:
JimLaney
JimLaney
I searched for "organizing restoration". got a substantial thread, hit printable version and realized that the hardest part would be editing to condense... so much good stuff.
Administrator
Boss
With over 186 thousand posts in the Spridgets forum alone, it would be the editing, condensing and organizing that would be monumentally time-consuming I think.
JimLaney
JimLaney
For a nube like me, it would be a great resource but it is more than I can take on or ask anyone else to do. I wonder if the Wiki software would be if any help? That is the way I have seen similar "guides" written up.
Does anyone on the BCF have any experience with Wiki?
Administrator
Boss
Once upon a time, we had a Wiki installed but the problem was not enough people took the time to contribute to it to make it really viable.
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
B Damaged threads in the gas tank Austin Healey 7
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
S Stripped Threads Austin Healey 10
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
vette Threads for the Water Temp Sender Austin Healey 6
R BJ7 spark plug threads Austin Healey 17
Mickey Richaud General MG Two More Threads! MG 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
Basil Admin Note Use Prefixes to filter threads you read MG 4
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
KVH TR4/4A Wrong Threads on New Fuel Pump? Triumph 13
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
S TR2/3/3A Spark plug threads Triumph 10
PatGalvin TR2/3/3A Heater Spacer Threads are a mystery Triumph 4
M stripped threads on master cyl Spridgets 12
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
Jer chasing spark plug threads on head? Spridgets 8
A TR2/3/3A TR-3A Windshiedl Tenex Peg Set Threads Triumph 2
T TR2/3/3A What size and threads for corner finisher on TR3A windshield Triumph 3
S Where are the threads from 11/7 - 11/17? Austin Healey 2
KVH What happened to all the threads between "today" and November 6? Triumph 6
TulsaFred Harmonic balancer threads Spridgets 2
J Stripped threads engine block Triumph 7
L Removing chrome from threads Spridgets 16
M Bajo bolt and rocker pedestal threads.. Austin Healey 6
J threads on the fill plug for the steering box? Austin Healey 1
DNK Threads Triumph 11
rikiwho123 uys what can be done to rstripped threads in head? Triumph 11
RickB Prestige Auto Trim zipout window- threads unravel Spridgets 1
J BN1 King Pin Nut Threads Austin Healey 1
T BE Quarter Elliptic Mounting Bolts - threads gone Spridgets 5
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
Ohiobugeye Metric or US Standard Threads? Spridgets 26
B shift lever threads Austin Healey 6
bthompson Nigel's new threads: a winter tale. Spridgets 5
davidk Stripped threads in oil pan front saddle block Triumph 12
BobbyD Stripping Aluminum Threads Triumph 17
M Block threads stripped torquing head Triumph 16
Dougal Front damper striped threads Austin Healey 30
B Manifold stud threads. MG 21
G What threads on 1500 oil sending unit? Spridgets 1
M Grease Nipple Threads Triumph 2
Morris 1500 oil filter threads Spridgets 4
Tinkerman Gear shift lever threads Triumph 21
JPSmit Gear Shift threads and trivia question Spridgets 1
