Lutz Kramer
Hallo from Germany,
last week a noise started to come from the engine compartment of my AH 3000 Mk III BJ8. This noise has a very high frequency and sounds like a turbine. It goes up with the rev of the engine. It’s no knocking or clacking or rattling!
What I’ve done so far is:
- rocker clearance checked --> OK
- compression on all 6 Zyl. is the same --> OK
- took the distributer out and checked for noises --> OK
- took the fan belt off, to make sure it’s not coming from the water pump or generator
- when depressing the clutch, the noise is still there!
- I tried to find the source with a statoscope and believe the sound is coming from the front end of the engine
My guess is, it could be
- a camshaft bearing or
- main shaft bearing
- missing rubber surface of the tensioner or the chain damper, so the chain runs on the metal surface of those two parts
Hopefully it’s the last guess, because otherwise I have to disassemble the engine.
I have to add the fact, that I did an overhaul on the transmission just 2 weeks ago. But I don’t think the noise is coming anywhere from the gear box, OD or first motion shaft, since the noise is not affected, when I depress the clutch which of course disengages the first motion shaft from the crank shaft.
May be anybody has already encountered a similar problem or has an idea, what the cause may be.
Thank you all!
Lutz
Thank you all!
Lutz
